On 03/05/2004 at 07:54, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.207 Platform: Windows ; Language(s) : C++ ;
--------- I refer to an older topic, Mikael did post the MSA Code as an example. My customgui/data is a treeview/tree structure. Now it works, that I set up the tree from my material, write it to the container, receive it within the gui, and display it with a treeview in the attribute manager. But now I need to get some data back to the material. If I select an item within the tree, my material has to know which one has selected. In the MSA code, I found the iCustomGui::Command. There, they send a parent message ( BFM_ACTION ). If I do so, my material receives a MSG_DESCRIPTION_VALIDATE. So I now can detect, that an item was selected. But I dont know which one. In the MSA code, they send some data with the message, where is that data received? I think in general, I have to write the tree data back to the container, but how?
On 04/05/2004 at 05:43, xxxxxxxx wrote:
Eventually the data from your tree should end up in SetDParameter() of the host node/material and get stored in the container. You'll just have to make sure that selection is stored with the datatype that you use with the tree GUI.
