On 16/04/2004 at 05:27, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.000 Platform: Language(s) : C.O.F.F.E.E ;
--------- Hi, this time i've got another question: I've tried to make the 8.0 SDK run in Visual C++ 6.0 but when opening the delivered .dsw Workspace file it says "Lines ending with only a carriage return have beern detected. These will be modified to include a line feed" When then trying to compile the project I get those Precompiler Errors: f:\programme\maxon\cinema_4d_r8\resource\_api\ge_math.h(1) : warning C4067: unexpected tokens following preprocessor directive - expected a newline f:\programme\maxon\cinema_4d_r8\resource\_api\ge_math.h(2) : fatal error C1004: unexpected end of file found After the Preprocessor directives there are no extra tokens but only newlines! Even when i manually insert newlines or linefeeds the same errors occur... what can be the cause? Can i find newer SDK Versions somewhere? (Haven`t found some on this site) Or are the new ones only delivered with updates or new purchases of CInema?
On 16/04/2004 at 15:51, xxxxxxxx wrote:
Please update to 8.2. (It's a free update.)
On 16/04/2004 at 15:54, xxxxxxxx wrote:
(And yes, the new SDK is included with the update.)
