Tool mode ?
    On 10/04/2004 at 04:31, xxxxxxxx wrote:
    Cinema 4D Version:   8.200
    Platform:   Windows  ;
    Hello! Is it possible to retrieve the mode that c4d is in? I would like to notify a plugin if the user has selected the rotate, translate or scale tool.
    Thanks
    On 10/04/2004 at 05:05, xxxxxxxx wrote:
    BaseDocument::GetAction()
    On 10/04/2004 at 05:57, xxxxxxxx wrote:
    Thanks, but is´nt that for the C++ SDK? I cant find any docs on it in the COFFEE SDK
    On 10/04/2004 at 08:38, xxxxxxxx wrote:
    upps. Hmm, I don´t think it´s possible then. you cannot get General settings of the document in COFFEE so this workaround doesn´t work either.
    On 13/04/2004 at 15:38, xxxxxxxx wrote:
    Samir is right. This is currently not possible in C.O.F.F.E.E.
    On 28/10/2004 at 14:16, xxxxxxxx wrote:
    Howdy,
    OK, so how does GetAction() work in C++? The SDK says this:
    LONG GetAction(void)
    Get the current tool in the editor.
    Return
    LONG
    The return values are the IDM_MOVE, IDM_SCALE etc. All these IDs are listed in c4d_symbols.coh in the resource folder of the main application. The IDs used need to be copied over manually.
    I tried this...
    LONG activeTool = doc->GetAction();
    if (activeTool == IDM_MOVE)
         GePrint("Move Tool active");
    ...but nothing happens.
    Then I tried this...
    GePrint("activeTool = "+LongToString(activeTool));
    ...and it printed out this: activeTool = 200000088
    In the c4d_symbols.coh file, it's listed: IDM_MOVE     = 12356,
    When it said, "The IDs used need to be copied over manually" I thought it meant that I have to copy that line and paste it into my plugin's header file with the other enum's.
    I'm a bit confused. Can someone steer me in the right direction?
    Adios,
    Cactus Dan
    On 02/11/2004 at 15:04, xxxxxxxx wrote:
    I guess that's because the former move tool was built into the CINEMA core and therefore had an IDM_* ID.
    In CINEMA R9, the move tool is implemented inside the Plugin Resource/modules/modeling, so the ID changed.
    The new ID is still part of the API, you can find it as ID_MODELING_MOVE in Resource/_api/ModelingIDs.h.
    Michael
    On 02/11/2004 at 17:57, xxxxxxxx wrote:
    Howdy,
    Ah, that works. Thanks Michael.
    Adios,
    Cactus Dan
