Crashing with Coffee
    On 07/04/2004 at 10:18, xxxxxxxx wrote:
    Cinema 4D Version:   8.100
    Platform:
    I'm trying to alter a polygon objects points positions. unfortunatly what i want to do causes crashes I can't explain. the following code, ist very similar to what I've tried and it works.
    main ( the_Document, the_Object )
    println("active");
    var p=the_Object->GetPoint(0);
    //if first points x-value is not -1
    //run coffee program
    if(p.x!=-1)
    var angle=cos(3.141592654*46.055/180);
    var array=the_Object->GetPoints();
    var count = sizeof(array);
    var i;
    for (i = 1; i < count; i++)
    //print(tostring(z)+" / " + tostring(angle) +"\n");
    array _.x=array _.z*angle;
    //array _.y=array _.z*angle;
    the_Object->SetPoints(array);
    //ensure that the first points x-value ist -1
    p.x=-1;
    the_Object->SetPoint(0,p);
    }____
    ________
    I get the list of points, change the x value and reset the list. perfekt. in the for-loop I've excluded a little code where i change the y value. if i enable it, i get a crash usually right away, sometimes i see the result and then it crashes. if I simply set the value of array[i].y to 0 , no problem. but as soon as i integrate the z value, kaboooom. Cinema crashes completely. if i do this : array[i].y = array[i].y+50; it works as well.
    ____really weird. and i just can't find a solution.
    the idices got lost... i copied it out of a different forum, where i was hoping for help. and it didn't display [i] there.
    so this is in my code
    array _[ i ].x=array[ i ].z*angle;
    //array[ i ].y=array[ i ].z*angle;_
    On 22/04/2004 at 18:12, xxxxxxxx wrote:
    As noted in another thread, please enclose code within code tags. Also, you might want to upgrade to 8.207 (or 8.503) and test the code there  (8.100 is unsupported). I don't see anything immediately wrong with your code.
    On 23/04/2004 at 02:11, xxxxxxxx wrote:
    thanks for the reply. i actually managed to get it work without changing anything, but using version 7. with version 8.5 it crashed.
