On 06/04/2004 at 19:05, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Mac ; Mac OSX ; Language(s) : C++ ;
--------- Howdy,
I've created a plug-in on the Mac using Codewarrior 9 (OS X and Classic) and would like to make it also available for the PC. I've read the threads in this forum regarding the problems compiling on a PC with Codewarrior 8 and I have a few questions:
Are the problems the same if you're compiling for the PC but using Codewarrior on a Mac?
Has anyone encountered these same problems with Codewarrior 9?
Can a plug in for the PC be tested on a Mac running Virtual PC and a demo version of Cinema 4D for PC?
Thanks in advance for any advice.
Adios, Cactus Dan
On 06/04/2004 at 22:59, xxxxxxxx wrote:
Code Warrior can not be used to compile plugins for Windows (neither the PC version or Mac version), Code Warrior produces some incompatible code with Visual C and Intel (which are THE Windows compilers), do a search on this forum for details. AFAIK CW9 is no different. As for Virtual PC, yes you can test plugins, but, due to how CINEMA handles the cursor for some functions (by hiding it and tracking the movement) you will find that CINEMA (and possibly your plugin) does not work correctly (or at least it didn't last time I tried Virtual PC with CINEMA). If using the mouse cursor to move/scale/rotate objects (when the cursor becomes hidden) does not affect your plugin then it should be fine.
On 06/04/2004 at 23:50, xxxxxxxx wrote:
You could compile your plugin with Visual Studio in Virtual PC... The problems with the mouse cursor can probably be fixed by setting the "Tablet" option in C4D.
On 07/04/2004 at 01:32, xxxxxxxx wrote:
Thank you I didn't know the Tablet option "fixed" it I can now use CINEMA via Remote Desktop too!
On 07/04/2004 at 17:57, xxxxxxxx wrote:
Howdy,
Thanks for the info.
Just one more question:
Virtual PC comes in different Windows operating systems, which one would be best for compiling C4D plug ins?
On 07/04/2004 at 22:51, xxxxxxxx wrote:
Makes little difference if you are just compiling and using CINEMA afaik. If I recall correctly then Win 98 runs faster on VPC since it uses less resources.
On 07/04/2004 at 23:00, xxxxxxxx wrote:
It might make sense to go with Windows 2000 or XP anyway, just to safeguard against a future C4D version doing away with 95/98 compatibility.
On 08/04/2004 at 05:12, xxxxxxxx wrote:
Thanks again.
