On 28/02/2004 at 16:03, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.503 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- I can get point array data from the PLA key, but can not set it to the PLA key with the "SetData()" function. What is wrong?
My code is shown below, and file is uploaded to the link.
http://www.c4djug.com/cache/PLA2.zip
main(doc,op) { //get sequence and key var plaseq= op->GetFirstTrack()->GetFirstSequence(); var plaky0= plaseq->GetFirstKey(); //get array data var pladata0= plaky0->GetPointTag()->GetData(); //check println(pladata0[0]); //Good //create new key and tag var plaky1= new(PLAKey); var pitag1= new(PointTag); //set the array to new tag pitag1->SetData(pladata0); //check var pladata1= pitag1->GetData(); println(pladata1[0]); //Bad }
On 28/02/2004 at 20:27, xxxxxxxx wrote:
OK, I understood that I need "Variable Changed", and to expand the array for the polygon.
