On 14/02/2004 at 09:35, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Mac OSX ; Language(s) : C.O.F.F.E.E ;
--------- I want to be able to save some data inside a c4d file (data created by a plug-in) so that, when the c4d file is saved, the data is saved along with it. This way, when the c4d file is loaded back, calling the plug-in again (a menu plug-in) it can access the previously saved data. Possible? Thank you very much in advance.
Rui Batista
On 15/02/2004 at 16:13, xxxxxxxx wrote:
In C++ you could store this in the document container under a unique ID. In C.O.F.F.E.E. this isn't officially supported, since there's no Get/SetContainer() in the docs for BaseDocument. But it seems to work anyway.
var bc = doc->GetContainer(); println(bc->GetString(UNIQUE_ID)); bc->SetData(UNIQUE_ID, "Test"); doc->SetContainer(bc);
To store many values, combine them into a container and store it as a sub-container with the unique ID. Then the values inside of it needn't have unique IDs.
On 16/02/2004 at 02:46, xxxxxxxx wrote:
Thank you very much, Mikael. I will give it a try. Anyway, how can I store a sub-container? It may be simpler than I'm thinking but I guess I never did anything similar.
On 16/02/2004 at 20:15, xxxxxxxx wrote:
Just use SetData() with a container, the GetContainer() to get it back. (I think.)
