Solved c4d 2024 "MENURESOURCE_SEPERATOR"
Previously, my plugin worked normally in 2023, but in 2024, the console prompted:
but,there have been no changes in the sample code for this section in the Python doc for 2024
I can only replace it with the number 2. “ menu.InsData(2, True) ”.Has there been any change in 2024?
相信我,可以的!
Hi @chuanzhen
This symbol rename to c4d.MENURESOURCE_SEPARATOR( fix the spelling ), you can add a version condition to your plugin or just use the int 2.
Cheers~
DunHou
Hi @chuanzhen
Cheers~
DunHou
@Dunhou Thanks!
相信我,可以的!
Hello @chuanzhen,
Thank you for reaching out to us. And thank you @Dunhou for providing an answer. @Dunhou is right, a developer of ours fixed the spelling error in the symbol in our C++ API, which then automatically has been propagated to Python.
@ferdinand Thanks,hope to fix spelling in c4dpython doc in future versions
相信我,可以的!
