Hey @pyr,
Thank you for reaching out to us. The sentence 'if i do the whole thing via obj.InsertUnder(null) i miss the material' is a bit ambiguous, how do you mean that? I assume you mean that when you load two documents A and B and then start copying objects over by either cloning them or removing them from A and inserting them into B, that you then miss material references. Because the call you show us will load both objects and materials found at f
into doc
A straightforward way to do what you want to do, parent everything that has been imported to a null, is to track the state of the top-level objects before and after the import. The difference between the states then tells you what to move where. In practice, there are some technical hoops to jump through, primarily the problem that you might run into dead references when you try to store objects references over the import process.
Result:
