Hi everyone!
I'm trying to set up the constraint tag, so this will pick the movement from another object. I need to do it strictly with Transform Constraint Tag.
I was playing around with code and different parameters, but one is driving me crazy, I just can't figure out how to set an object as a target. Likewise, I used SearchObject, I got GUID nothing is going to help.
I digged through the forums and found out that the UI ID of the target matters (10001), but I find no samples how to use the ID properly in Python scripts. Appreciate any help!
I work on Windows 11
Cinema 4D 2023.2.2
from c4d import gui
target_obj = doc.SearchObject("Test")
def addConstraint():
objects = doc.GetActiveObjects(1)
print(objects)
my_obj = doc.SearchObject("Test")
for obj in objects:
tag = obj.MakeTag(c4d.Tcaconstraint)
print(f"Your tag: {tag}")
tag()[c4d.ID_CA_CONSTRAINT_TAG_PSR] = True
tag()[c4d.ID_CA_CONSTRAINT_TAG_PSR_LINK] = my_obj
tag()[c4d.ID_CA_CONSTRAINT_TAG_PSR_P_OFFSET] = c4d.Vector(5,0,0)
tag()[c4d.ID_CA_CONSTRAINT_TAG_PSR_MAINTAIN] = True
tag.SetName("Boo")
addConstraint()
