Unsolved C4d Connector problem in 2024
I just installed 2024 and I can't get the "send to IDE" button to work anymore. It just does nothing.
VS Code connects and I can actually write stuff in VS Code and use "Execute in C4d", but I can't send from C4D.
Also, when starting VS Code I get this error: "Incorrect path for c4d.path, autocompletion will not work" even though I did update the path to "C:\Program Files\Maxon Cinema 4D 2024" . Autocompletion actually works even though it says it will not.
2023 still works fine.
Any ideas how to fix it?
Hi the plugin is going to be updated today.
Hi @filipst, I've published a new version of the Visual Studio Connector, it is available here and should be soon available via the VS Code marketplace.
However while investigating the issue, I found out another one which was added very lately and is more critical since it prevent Cinema 4D to send data to the Vs Code extension. Sadly this will require a fix on Cinema 4D side. I'm trying to have this fix for Cinema 4D as soon as possible out.
Yep, that's the issue I mentioned in my first post, first sentence.
Thanks for confirming that it is indeed a bug!
Hi just to let you know that we have a fix, and it will be available in the next version :) I'm going to update this topic once it's public.
Hi @filipst just to let you know that with the hotfix released yesterday(20/09/2023). The issue within Cinema 4D has been solved.
In the same time make sure to use the latest version of the add-on in VsCode (v1.1.0).
