Hey @simonator420,
Thank you for reaching out to us. And thank you @Dunhou for providing a solution. You should however be aware that Dunhou's solution requires his proprietary library as he states below. I think you should give it a spin because it is quite useful.
When you must remain within the bounds of the Cinema 4D standard library, find an example for how to do that below.
PS: I have added the example below to the code examples of the upcoming release alongside the standard renderer example.
Result:
Code:
#coding: utf-8
"""Demonstrates setting up a Redshift node material composed out of multiple nodes.
Creates a new node material with a graph in the Redshift material space, containing two texture
nodes and a mix node, in addition to the default core material and material node of the material.
Topics:
* Creating a node material and adding a graph
* Adding nodes to a graph
* Setting the value of ports without wires
* Connecting ports with a wires
* (Asset API): Using texture assets in a node graph
__author__ = "Ferdinand Hoppe"
__copyright__ = "Copyright (C) 2023 MAXON Computer GmbH"
__date__ = "01/09/2023"
__license__ = "Apache-2.0 License"
__version__ = "2023.2.0"
import maxon
doc: c4d.documents.BaseDocument # The active document.
"""Runs the example.
# The asset URLs for the "RustPaint0291_M.jpg" and "Sketch (HR basic026).jpg" texture assets in
# "tex/Surfaces/Dirt Scratches & Smudges/". These could also be replaced with local texture URLs,
# e.g., "file:///c:/textures/stone.jpg". These IDs can be discovered with the #-button in the info
# area of the Asset Browser.
urlTexRust: maxon.Url = maxon.Url(r"asset:///file_edb3eb584c0d905c")
urlTexSketch: maxon.Url = maxon.Url(r"asset:///file_3b194acc5a745a2c")
# The node asset IDs for the two node types to be added in the example; the texture node and the
# mix node. These and all other node IDs can be discovered in the node info overlay in the
# bottom left corner of the Node Editor. Open the Cinema 4D preferences by pressing CTRL/CMD + E
# and enable Node Editor -> Ids in order to see node and port IDs in the Node Editor.
idTextureNode: maxon.Id = maxon.Id("com.redshift3d.redshift4c4d.nodes.core.texturesampler")
idMixNode: maxon.Id = maxon.Id("com.redshift3d.redshift4c4d.nodes.core.rscolormix")
idCoreMaterialNode: maxon.Id = maxon.Id("com.redshift3d.redshift4c4d.nodes.core.material")
# Instantiate a material, get its node material and the graph for the RS material space.
material: c4d.BaseMaterial = c4d.BaseMaterial(c4d.Mmaterial)
if not material:
raise MemoryError(f"{material = }")
nodeMaterial: c4d.NodeMaterial = material.GetNodeMaterialReference()
graph: maxon.GraphModelRef = nodeMaterial.AddGraph(
maxon.Id("com.redshift3d.redshift4c4d.class.nodespace"))
if graph.IsNullValue():
raise RuntimeError("Could not add RS graph to material.")
doc.InsertMaterial(material)
# Attempt to find the core material node contained in the default graph setup.
result: list[maxon.GraphNode] = []
maxon.GraphModelHelper.FindNodesByAssetId(graph, idCoreMaterialNode, True, result)
if len(result) < 1:
raise RuntimeError("Could not find standard node in material.")
standardNode: maxon.GraphNode = result[0]
# Start modifying the graph by opening a transaction. Node graphs follow a database like
# transaction model where all changes are only finally applied once a transaction is committed.
with graph.BeginTransaction() as transaction:
# Add two texture nodes and a blend node to the graph.
rustTexNode: maxon.GraphNode = graph.AddChild(maxon.Id(), idTextureNode)
sketchTexNode: maxon.GraphNode = graph.AddChild(maxon.Id(), idTextureNode)
mixNode: maxon.GraphNode = graph.AddChild(maxon.Id(), idMixNode)
# Set the default value of the 'Mix Amount' port, i.e., the value the port has when no
# wire is connected to it. This is equivalent to the user setting the value to "0.5" in
# the Attribute Manager.
mixAmount: maxon.GraphNode = mixNode.GetInputs().FindChild(
"com.redshift3d.redshift4c4d.nodes.core.rscolormix.mixamount")
mixAmount.SetDefaultValue(0.5)
# Set the path sub ports of the 'File' ports of the two image nodes to the texture URLs
# established above. Other than for the standard node space image node, the texture is
# expressed as a port bundle, i.e., a port which holds other ports. The texture of a texture
# node is expressed as the "File" port, of which "Path", the URL, is only one of the possible
# sub-ports to set.
pathRustPort: maxon.GraphNode = rustTexNode.GetInputs().FindChild(
"com.redshift3d.redshift4c4d.nodes.core.texturesampler.tex0").FindChild("path")
pathSketchPort: maxon.GraphNode = sketchTexNode.GetInputs().FindChild(
pathRustPort.SetDefaultValue(urlTexRust)
pathSketchPort.SetDefaultValue(urlTexSketch)
# Get the color output ports of the two texture nodes and the color blend node.
rustTexColorOutPort: maxon.GraphNode = rustTexNode.GetOutputs().FindChild(
"com.redshift3d.redshift4c4d.nodes.core.texturesampler.outcolor")
sketchTexColorOutPort: maxon.GraphNode = sketchTexNode.GetOutputs().FindChild(
mixColorOutPort: maxon.GraphNode = mixNode.GetOutputs().FindChild(
"com.redshift3d.redshift4c4d.nodes.core.rscolormix.outcolor")
# Get the fore- and background port of the blend node and the color port of the BSDF node.
mixInput1Port: maxon.GraphNode = mixNode.GetInputs().FindChild(
"com.redshift3d.redshift4c4d.nodes.core.rscolormix.input1")
mixInput2Port: maxon.GraphNode = mixNode.GetInputs().FindChild(
"com.redshift3d.redshift4c4d.nodes.core.rscolormix.input2")
coreDiffusePort: maxon.GraphNode = standardNode.GetInputs().FindChild(
"com.redshift3d.redshift4c4d.nodes.core.material.diffuse_color")
# Wire up the two texture nodes to the blend node and the blend node to the BSDF node.
rustTexColorOutPort.Connect(mixInput1Port, modes=maxon.WIRE_MODE.NORMAL, reverse=False)
sketchTexColorOutPort.Connect(mixInput2Port, modes=maxon.WIRE_MODE.NORMAL, reverse=False)
mixColorOutPort.Connect(coreDiffusePort, modes=maxon.WIRE_MODE.NORMAL, reverse=False)
# Finish the transaction to apply the changes to the graph.
transaction.Commit()
# Insert the material into the document and push an update event.
