Solved Breaking Tags Out Of A Shared Folder
I'm working on a project that is made up of multiple tag plugins. What I'm trying to do is have the tags all separate in the list of Tags instead of under one folder.
Below I have a screenshot of the compiled base SDK for visual purposes.
So what I'm looking for is to have the three plugins inside of the "Cinema4dsdk Tags" dropdown not be inside of a submenu.
I know you can do this by compiling them all as separate projects but I would prefer to avoid going that route if there is an alternative.
Any help would be appreciated.
John Terenece
Hi @JohnTerenece, after searching few hours, it appear that this is not possible to customize the Tag plugin, neither in R21 or in newer version. So the only solution would be to separate your project.
Thanks for the response, that's what I was afraid of.
John Terenece
