Hello @Easan,
Welcome to the Plugin Café forum and the Cinema 4D development community, it is great to have you with us!
Getting Started
Before creating your next postings, we would recommend making yourself accustomed with our Forum and Support Guidelines, as they line out details about the Maxon SDK Group support procedures. Of special importance are:
About your First Question
Please excuse the delayed answer to your posting.
Assuming you're working with the 'RS Shader Graph' materials (please try specifying complete information in you next postings), I'd suggest you having a look into awesome example from Ferdinand: https://plugincafe.maxon.net/topic/14753/script-that-converts-redshift-materials-back-to-c4d-standard-ones?_=1691157330869
You can find simplified adopted code to your case below, which you can use as a starting point for your further investigations.
Ilia
Code:
import c4d, maxon, typing
from c4d.modules.graphview import *
doc: c4d.documents.BaseDocument # The active document
RS_MATERIAL_NODE_TYPENAME: str = 'Material'
ID_NODE_TYPENAME: int = 1001 # The location at which type names are stored in an operator container.
def iterTree(tree: GvNode) -> typing.Iterator[GvNode]:
"""Yields all nodes in the given shader tree #tree.
yield tree
for child in tree.GetChildren():
for desc in iterTree(child):
yield desc
mat = doc.GetActiveMaterial()
if mat is None or not mat.CheckType(c4d.Mrsgraph):
raise ValueError("There is no selected Redshift Shader Graph")
# We traverse branches of this shader graph
for info in mat.GetBranchInfo(c4d.GETBRANCHINFO_ONLYWITHCHILDREN):
if info.get("name", "").lower() != "node":
continue
head: c4d.GeListHead | None = info.get("head", None)
if not isinstance(head, c4d.GeListHead):
raise RuntimeError(f"Malformed RS graph without head: {info}")
root: GvNode = head.GetFirst()
for node in iterTree(root):
# Get the data of container of #node which among other things contains its real type name.
opData: c4d.BaseContainer = node.GetOperatorContainer()
if opData[ID_NODE_TYPENAME] != RS_MATERIAL_NODE_TYPENAME: # filter out all non-material nodes
continue
print(f'Diffuse weight: {node[c4d.REDSHIFT_SHADER_MATERIAL_DIFFUSE_WEIGHT]}')
# Pushes an update event to Cinema 4D
