Use the tab name, Open that window?
Can I use the tab name and open that window?
I want to switch the Viewports and Project Settings windows to Python.
Access to tabs in the SDK is rarely written.
Asking for help. Thank You.
Hello @ymoon,
thank you for reaching out to us. Neither the Python nor C++ Cinema 4D API do not provide control over existing/native window and dialog elements of Cinema 4D. You have only access to the things you have implemented yourself. This is an intentional decision and not a feature gap.
In the Cinema 4D API, you do not have control over the active tabs in a layout. What you can do is:
DescriptionCutomGUI
in Python, other than in C++, setting the active tab is not possible.ActiveObjectManager_SetMode
with which you can switch the mode of the Attribute Manager. It has no direct equivalent in Python, but you can emulate is functionality with this code:"""Opens the projects settings in the Attribute Manager.
c4d.gui.ActiveObjectManager_SetObject(
c4d.ACTIVEOBJECTMODE_DOCUMENT, # The mode to set, the document mode herel.
c4d.BaseList2D(c4d.Onull), # A dummy object which does not matter in this case,
# because there is only one relevant document node.
c4d.ACTIVEOBJECTMANAGER_SETOBJECTS_OPEN # Open a new AM if there is none open.
PS: Please state your used version of Cinema 4D in the future when it is not the most recent one.
There is no command to invoke the viewport window, so I was looking for an alternative. I will tagging the version in the next post. (R2023) Thank You.
