I have a Python Generator Object that returns a Spline Object. I want to use this spline for the distribution of a Cloner Object, but it does not generate any clones on the spline.
The spline works fine when used for Generators such as Sweep, Extrude, Loft etc.
The Python Generator Code:
spline = c4d.SplineObject(pcnt=4, type=c4d.SPLINETYPE_LINEAR)
spline.ResizeObject(pcnt=4, scnt=1)
spline.SetPoint(id=0, pos=c4d.Vector(0, 0, 0))
spline.SetPoint(id=1, pos=c4d.Vector(100, 100, 100))
spline.SetPoint(id=2, pos=c4d.Vector(200, 200, 200))
spline.SetPoint(id=3, pos=c4d.Vector(300, 300, 300))
spline.SetSegment(id=0, cnt=4, closed=False)
spline.Message(type=c4d.MSG_UPDATE)
return spline
The Scene File:
PyGenSplineAndCloner.c4d
I would appriciate it if you could check to see if it is a bug or I am missing somthing in the code.
