Solved Reading unicode from file Python
Hey,
Having an issue trying to read unicode characters from a CSV file.
I am not very experienced with python so apologies in advance.
Context:
We use a CSV as a list of names, places, organisations etc read them in c4d and render them as images with the files named as per the column we select from the CSV.
Some names of people or their tribe names are in different languages, for us locally it is Māori, which as a lot of ā,ō,ū characters.
Our python code below. I have tried adding in "data.decode('utf8')" but this didn't help, or rather it is likely I am doing it wrong.
import csv
global Output
global TotRow
global TotCol
data = []
with open(CSV) as csv_file:
    reader = csv.reader(csv_file)
    for row in reader:
        data.append(row)
row = max(0, min(RowSel, len(data)-1))
col = max(0, min(ColSel, len(data[0])-1))
Output = data[row][col]
TotRow = len(data)
TotCol = len(data[0])
Any advise would be greatly appreciated
Thanks, I guess..
For anyone else coming across this issue, to decode in python you need to ensure that you're using the correct encoding when reading the CSV file. Even if the CSV file is already encoded to what you are expecting. To make it work for us we did the below:
with open(CSV, encoding='utf-8') as csv_file:
Rather than
Hello @A-I,
Welcome to the Plugin Café forum and the Cinema 4D development community, it is great to have you with us!
Getting Started
Before creating your next postings, we would recommend making yourself accustomed with our Forum and Support Guidelines, as they line out details about the Maxon SDK Group support procedures. Of special importance are:
About your First Question
Your question is out of the scope of the support on this forum, namely:
We cannot provide support on learning either C++, Python or one of its popular third party libraries
Hence the thread is moved to General Talk section.
As a general suggestion, make sure you encode your csv data properly when creating your files, then the data.decode('utf8') that you''ve mentioned above should do the trick.
Ilia
Thanks, I guess..
Rather than
