Hi there,
I have a Null with userdata and a button in it.
I also have an Xpresso tag and a Python Node that I want it to listen a message from that button. The button ID is 10.
In my research I wasn't able to find any examples for what I need, so I tried this code that I found.
I know this is for Python Generator obj, but I want something similar, and to learn how to detect a button from my userdata and then run an action.
Thanks a lot
def message(mid, data):
if mid is c4d.MSG_DESCRIPTION_COMMAND:
if not isinstance(data, dict) or "id" not in data:
raise RuntimeError("Malformed message data.")
senderDescId = data["id"]
if senderDescId[0].id == c4d.ID_USERDATA and senderDescId[1].id == 10:
print ("User data button has been pressed.")
# then run an action in main() function
# waiting for the right message before running anything...
