Solved Setting Noise as the Shader in a Displacer
I am trying to set the Shader field in the Displacemtn object to Noise. However, the filed is not filled.
Here the code.
What am I doing wrong?
from typing import Optional
doc: c4d.documents.BaseDocument  # The active document
op: Optional[c4d.BaseObject]  # The active object, None if unselected
    displacer = c4d.BaseObject(c4d.Odisplacer)
    doc.InsertObject(displacer)
    shd = c4d.BaseList2D(c4d.Xnoise)
    #displacer[c4d.ID_MG_SHADER_SHADER] = shd
    displacer.InsertShader(shd)
Ok, I understand it now better, thanks.
@pim
I solved it.
You must insert the shader into the document and then insert it in the displacer
    doc.InsertShader(shd)
    #displacer.InsertShader(shd)
Hey @pim,
Thank you for reaching out to us. Your first code example was correct, but you had commented out the line where you referenced the shader; which then will of course lead to a an object with no referenced shader. Inserting the shader and referencing it are two separate things. And since the Displace object owns the shader in this case, it should be the entity below which the shader is being inserted.
The document is not the correct place to insert the shader. Inserting a shader primarily makes sure that the shader is attached to the scene graph and sometimes one can get away with inserting shaders in wonky places (e.g., insert a shader referenced by material A under material B). But doing this eventually will lead to crashes.
You should also first insert the shader and then reference it or call other shader related functions.
PS: I have removed your "Solved" flag, since the code you show there is not correct.
Result:
Code
    shader = c4d.BaseList2D(c4d.Xnoise)
    if None in (displacer, shader):
        raise MemoryError(f"{displacer = }, {shader = }")
    displacer.InsertShader(shader)
    displacer[c4d.ID_MG_SHADER_SHADER] = shader
