Creating a Viewport
On 27/09/2003 at 03:46, xxxxxxxx wrote:
Cinema 4D Version: 8.200
Platform:
Is it possible to create a viewport (with a GUI plugin) that can hold objects? So the user can move and rotate around the objects.
What I would like is to make a plugin that has a small viewport on the dialog, which shows the active object in it.
C4D UV Mapper has something similar, except it shows a uv map of the object, i want to just display the actual object, so I can rotate around it.
Is there a built in control I can use? or will I have to make my own control?
Thanks
On 02/10/2003 at 05:40, xxxxxxxx wrote:
There's no such built-in control, though it's a good suggestion.
