Solved Selections in python
Hi, how to work with selections in python, I need a script that receives two selected polygons as input and completes the selection of polygons to a rectangle with limited selected polygons
Hello @SemyonShapoval,
Welcome to the Plugin Café forum and the Cinema 4D development community, it is great to have you with us!
Getting Started
Before creating your next postings, we would recommend making yourself accustomed with our Forum and Support Guidelines, as they line out details about the Maxon SDK Group support procedures. Of special importance are:
About your First Question
The goal you're trying to achieve is not impossible (to an extent of ambiguity produced by its lacking any details description). However, it is out of support scope for this forum:
If necessary, we will provide code examples, but we will not provide full solutions or design applications.
You can refer to the github Extrude polygons example as a starting source of info on how to work with polygon objects and selected polygon data. You can use a simple code snippet below as a starting point for your investigation.
There's no such functionality in Cinema4D, so you need to develop proper algorithm yourself. However, it seems there're quite many of pitfalls and edge cases one needs to face for the functionality you describe (e.g. polys being triangles and quads, poorly polygonized meshes, meshes with islands etc.).
Let me know if you have any further questions.
Ilia
A starting point code snippet that prints out coordinates of the selected polygons:
doc: c4d.documents.BaseDocument
    ops: list[c4d.BaseObject] = [item for item in doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_CHILDREN) if item.CheckType(c4d.Opolygon)]
    if not len(ops):
        raise Exception('Please select polygons')
    pOp: c4d.PolygonObject = ops[0]
    print(f'Selected object: {pOp.GetName()}')
    selectedPolyIdcs: list[int] = [i for i, state in enumerate(pOp.GetPolygonS().GetAll(pOp.GetPolygonCount())) if state]
    if not len(selectedPolyIdcs):
    polygons: list[c4d.CPolygon] = pOp.GetAllPolygons()
    points: list[c4d.Vector] = pOp.GetAllPoints()
    for sPolyIdx in selectedPolyIdcs:
        sp: c4d.CPolygon = polygons[sPolyIdx]
        spPoints: list[c4d.Vector] = [points[idx] for idx in (sp.a, sp.b, sp.c, sp.d)]
        print(f'  Poly #{sPolyIdx}: {", ".join([str([p[i] for i in range(3)]) for p in spPoints])}')
Getting Started
Ilia
    if not len(ops):
without further questions or postings, we will consider this topic as solved by Friday, the 11th of august 2023 and flag it accordingly.
Maxon SDK Group
