Solved TreeView DropDown Menu
Hi, it may be a foolish task but I would like to have different value in each row after I make the selection in the dropdown menu. This way it displays same value for every row. Could you help me with that?
class ListView(c4d.gui.TreeViewFunctions):
    def __init__(self):
        self.selectedEntry = 1000
    def GetDropDownMenu(self, root, userdata, obj, lColumn, menuInfo):
        menuInfo["entry"] = self.selectedEntry
        menuInfo["menu"][1000] = "Material 1"
        menuInfo["menu"][1001] = "Material 2"
        menuInfo["menu"][1002] = "Material 3"
        menuInfo["menu"][1003] = "Material 4"
        menuInfo["state"] = int(menuInfo["state"])
    def SetDropDownMenu(self, root, userdata, obj, lColumn, entry):
        self.selectedEntry = entry
        print(f"User selected the entry with the ID: {entry}")
Hello @simonator420,
Thank you for reaching out to us. As announced here, Maxon is currently conducting a company meeting. Please understand that our capability to answer questions is therefore limited at the moment.
I am slightly confused about the nature of your questions, especially in the context of the reply from @mogh. TreeViewFunctions.GetDropDownMenu lets you define the content of drop down menus in a TreeView, and the slightly ill named SetDropDownMenu lets you react to an item being selected in such menu.
The 'problem' with your code snippet is that you do not differentiate the drop down gadgets which are set in GetDropDownMenu. Like many methods of TreeViewFunctions it is called for each cell in the tree view table, where lColumn denotes the column as defined in your TreeViewCustomGui.SetLayout call, and obj denotes an item in your root, so sort of the row in the tree.
lColumn becomes meaningless when your tree view has only one column of type LV_DROPDOWN. How to make sense of obj, depends on the shape of the data you passed as root. When root root is just a list[object], you could for example alternate between even and odd rows like this.
    self, root: list[object], userdata: any, obj: object, lColumn: int, menuInfo: dict):
    """Simple example for defining the menu content based on the position of #obj in #root.
    index: int = root.index(obj)
    if index % 2 == 0:
        menuInfo["menu"][1000] = "Even row first option"
        menuInfo["menu"][1001] = "Even row second option"
        menuInfo["menu"][1000] = "Odd row first option"
        menuInfo["menu"][1001] = "Odd row second option"
In practice, the content of a drop down is more likely to be determined based on the fields of obj (e.g., if obj.a == "foo" then Menu1 else Menu2)rather than its relative position in root (be it a list-like or tree-like data structure).
Hi @simonator420,
you use the same ID for each row I guess, in your code above you would need to ofset every row by a certain amount for the IDs
I can not give you a working code from your snippet.
self.selectedEntry = 1000 + offset
kind regards,
mogh
    if index % 2 == 0:
