Hello @ThomasB,
Thank you for reaching out to us. The concept of a disk levels is tied to (manually) serializing scene data with c4d.storage.HyperFile, and is metadata for differentiating reading different versions.
:information_source: This also means that when for example your ObjectData plugin is storing all data in its data container, i.e., as parameters reflected in the c4d.BaseContainer returned by BaseList2D.GetData , the concept of a disk level is meaningless to you. |
Relevant become disk levels only when a c4d.plugins.NodeData derived plugin hook overwrites NodeData.Read
, .Write
and .CopyTo
(you must always implement all three of them). In NodeData.Read
you get then passed in the disk level of the node to be loaded. Disk levels are not a mechanism to run multiple plugin versions in parallel, 'load an older plugin' as your posting seems to imply, but to enable newer versions of a plugin to deal with data serialzed by an older version in a different format.
So, let us assume we have for example two versions V1
and V2
of a plugin of type Foo
, both saving custom data with a Read
and Write
method. We can now imagine that in a simplified analogy, for the same scene and node:
Foo.Write[V1]
- Writes {"data": (0, 1, 2)}
Foo.Write[V2]
- Writes {"data_collection": [(True, 0), (True, 1), (True, 2)]}
I.e., V2
saves more data and data in a different form than V1
. In practice this would be data in the form of HyperFile
, but imagining things as dict
data makes a much more tangible example. Disk levels then allow a V2
plugin version to also deal with data written by V1
version. But the disk level is just metadata, it does not do anything on its own, the V2
Foo.Read
would have to actively support both V1
and V2
data, as pseudo code:
def Read(self, data: dict, diskLevel: int) -> None:
"""V1 Foo.Read.
Reads only V1 data. The data form is:
{"data": (0, 1, 2)}
if diskLevel != 1:
raise IOError("Node data is of unsupported version.")
points: list[int] | None = data.get("data", None)
if points is None:
raise IOError("Node contains malformed data.")
# Let the read data contribute to the plugin state.
self._points: list[int] = points
"""V2 Foo.Read.
Has been fashioned to read both V1 and V2 data. The two hypothetical forms are:
V1: {"data": (0, 1, 2)}
V2: {"data_collection": [(True, 0), (True, 1), (True, 2)]}
In practice this would be data in the HyperFile format, this example just illustrates the
principle.
if diskLevel not in (1, 2):
points: list[int] | None = []
states: list[bool] | None = []
# Deal with V1 data.
if diskLevel == 1:
if points is None:
states = [True for _ in points]
# Deal with V2 data.
elif diskLevel == 2:
collection: dict[str, list[tuple[bool, int]]] | None = data.get("data_collection", None)
if collection is None:
states = [n[0] for n in collection]
points = [n[1] for n in collection]
self._states: list[bool] = states
In the front end, this then bubbles up in the form of c4d.C4DAtom.Read
and .Write
but these call just the respective NodeData
implementations in addition to (de-)serializing the data container itself.
