Hello @Dunhou,
Thank you for reaching out to us and for pointing out the error in this script.
The script has not been updated yet for 2023 and is still using old Nodes API calls. The S26 method maxon.GraphNode.IsSelected was already deprecated in S26 in favor of the S26 method maxon.GraphModelHelper.IsNodeSelected. In 2023, the GraphNode
method has been removed and you now must use maxon.GraphModelHelper.IsNodeSelected (2023.2).
I.e., you must change this:
# Create a list of the selected ones.
selectedNodes = []
for node in nodes:
if node.IsSelected():
selectedNodes.append(node)
to this:
selectedNodes = []
for node in nodes:
if maxon.GraphModelHelper.IsNodeSelected(node):
As an FYI: A lot of functionalities have been moved from GraphNode
and GraphModelRef
to GraphModelHelper
. We will update the GitHub script/provide a new one for 2023. Find below the full script updated for 2023.
Code:
Copyright: MAXON Computer GmbH
Author: Manuel Magalhaes
Description:
Retrieve the selected node material and group the node that are selected.
Class/method highlighted:
- MoveToGroup
- IsSelected
import maxon
# Retrieve the selected BaseMaterial
mat = doc.GetActiveMaterial()
if mat is None:
raise ValueError("There is no selected BaseMaterial")
# Retrieve the reference of the material as a node material.
nodeMaterial = mat.GetNodeMaterialReference()
if nodeMaterial is None:
raise ValueError("Cannot retrieve node material reference")
# Retrieve the current node space Id
nodespaceId = c4d.GetActiveNodeSpaceId()
# Retrieve the Nimbus reference for a specific node space
nimbusRef = mat.GetNimbusRef(nodespaceId)
if nimbusRef is None:
raise ValueError("Cannot retrieve the nimbus ref for that node space")
# Retrieve the graph corresponding to that node space.
graph = nimbusRef.GetGraph()
if graph is None:
raise ValueError("Cannot retrieve the graph of this nimbus ref")
# Get the root of the GraphNode
root = graph.GetRoot()
# Retrieve all nodes, child of the root node
nodes = []
root.GetChildren(nodes, maxon.NODE_KIND.NODE)
selectedNodes = []
for node in nodes:
# Group all the selected nodes in an empty node.
groupRoot = maxon.GraphNode()
# To modify a graph, modification must be done inside a transaction. After
# modifications are done, the transaction must be committed.
with graph.BeginTransaction() as transaction:
graph.MoveToGroup(groupRoot, maxon.Id("idOfMyGroup"), selectedNodes)
transaction.Commit()
# Pushes an update event to Cinema 4D
