Solved How to find out if document is rendering from a python tag
Hello guys,
how can I find out if a document is rendering? I tried the following code with mixed results.
What works for me is the following.
All of these methods return True if their respective task runs.
c4d.documents.GetBatchRender()
print(batch.IsRendering())
print(c4d.CheckIsRunning(c4d.CHECKISRUNNING_EXTERNALRENDERING))
print(c4d.modules.takesystem.IsTakeRenderRunning())
What does not work are the following methods which simply return always 0
print(c4d.CheckIsRunning(c4d.CHECKISRUNNING_EDITORRENDERING))
print(c4d.CheckIsRunning(c4d.CHECKISRUNNING_INTERACTIVERENDERING)
I'm using all of this inside def main() of a python tag if that helps.
Sebastian
Hi @HerrMay sadly having something working within the main will be a bit tricky, but this can be easily tested with message and more especially the MSG_MULTI_RENDERNOTIFICATION
Find below a script run from a Python Tag.
from typing import Optional
doc: c4d.documents.BaseDocument # The document evaluating this tag
op: c4d.BaseTag # The Python scripting tag
flags: int # c4d.EXECUTIONFLAGS
priority: int # c4d.EXECUTIONPRIORITY
tp: Optional[c4d.modules.thinkingparticles.TP_MasterSystem] # Particle system
thread: Optional[c4d.threading.BaseThread] # The thread executing this tag
    # Called when the tag is executed. It can be called multiple time per frame. Similar to TagData.Execute.
    # Write your code here
    pass
def message(id: int, data: object) -> bool:
    if id == c4d.MSG_MULTI_RENDERNOTIFICATION and data["start"]:
        print(data)
Note that the MSG_MULTI_RENDERNOTIFICATION in Python does not contain the context from which a render was started via the flag argument as it is in C++. I added it, so it will be in one of the next version of Cinema 4D.
Finally note that some IPR from external render engine may not work, as they bypass completely the Cinema 4D rendering pipeline.
    pass
        print(data)
Hi @m_adam,
thanks for the explanation and your example code. That will absolutely suffice my needs. :hugging_face:
Good to know though that additional information may be available in the future.
Sebastian
