Could you please suggest me, how to make tag info available in object's properties, like here:
By default, tag properties are displayed separately, only when tag is selected.
Thanks in advance,
Sergey (Yesbird).
Thanks in advance,
Sergey (Yesbird).
YB
hi,
if you defined TAG_MULTIPLE when you register your tag, the tag will not be displayed in the attribut manager when you select the object.
Other than that, i did not found anything special to do.
With the latest version (i think it was introduced in r25) you have a parameter on each tag to expose the tag on the object ID_EXPOSETAB
that must be set to true.
Manuel
hi,
Manuel
Thanks, @Manuel.
The reason was in definition of TAG_MULTIPLE at the moment of registration. Now the tag properties are displayed as I was expecting.
YB
YB
