Handles Problem...
On 14/09/2003 at 16:51, xxxxxxxx wrote:
Cinema 4D Version: 8.207
Platform: Windows ;
I have some handles for my object plugin but I ran into a problem. When using the handles to control a Real field with Meter or no "units" then it works perfectly but when using it for a field that has percentage units its range is too wide. Means when moving the handle 100 units then I want the percentage field to be at 100% but it´s at 10000%.
ok, so this seems to be a simple task, just divide the resulting value with 100 and it should work. But it´s not. Then the handle is placed wrong again :
So, can somebody help me out here. Where or how to get the correct behavior (or where to divide...)
Heres a code snippet (using a vector field, x component) :
Bool DPDub::MoveHandle(PluginObject *op, PluginObject *undo, const Matrix &tm, LONG hit_id, LONG qualifier)
BaseContainer *src = undo->GetDataInstance();
BaseContainer *dst = op->GetDataInstance();
Vector vval = tm.off;Vector rot = src->GetVector(DBDUB_SCA);
switch (hit_id)
{case 4:
vval.x+=src->GetVector(DBDUB_SCA).x+vval.x*0.001;
dst->SetVector(DBDUB_SCA,Vector(FCut(vval.x,0,10000),rot.y,rot.z));
break;
DrawViews(DA_NO_THREAD|DA_ONLY_ACTIVE_VIEW);
return TRUE;
Thanks
On 18/09/2003 at 02:06, xxxxxxxx wrote:
ok, got it already.
On 25/08/2009 at 13:58, xxxxxxxx wrote:
May I ask what the solution was?
I also try to implement some handles, using MoveHandle() and my handles shoot away into space if I dare move the mouse too quickly.
How did you solve it?
I want my handle to behave like the handle of the Bend deformer: I want to move the handle smoothly, like it was a normal object.
Jack
On 25/08/2009 at 14:11, xxxxxxxx wrote:
Further explanation:
I have an object with several child objects. By using handles, I want to user to move the children, without having to move select those objects in the Object Manager. So I draw a handle at each of my children, check them with DetectHandle() and return a nice handle id.
My MoveHandle() function looks like this:
Bool MyPlugin::MoveHandle(PluginObject \*op, PluginObject \*undo, const Matrix &tm;, LONG hit_id, LONG qualifier) \> { \> // val now contains the vector from old \> // handle position to new handle position, right? \> Vector val = tm.off; \> \> // Get the child object that correlates to \> // the handle (hit_id == 0 will get the first \> // child, hit_id == 1 will get the second, etc) \> BaseObject \*pobj = GetSubObjByIndex(op, hit_id); \> \> Vector oldpos = Vector(); \> if (pobj) oldpos = pobj->GetPos(); \> Vector newpos = Vector(); \> \> if (pobj) pobj->SetPos(newpos); \> // Prevent the handle from shooting away \> // All my efforts were futile, so far \> newpos.x = FCut(oldpos.x + tm.off.x, 0.0f, (Real)MAXRANGE); \> newpos.y = FCut(oldpos.y + tm.off.y, 0.0f, (Real)MAXRANGE); \> newpos.z = FCut(oldpos.z + tm.off.z, 0.0f, (Real)MAXRANGE); \> \> // Set the new position as position of the \> // child object \> if (pobj) pobj->SetPos(newpos); \> \> return TRUE; \> }
Thanks in advance for any help!
Jack
On 25/08/2009 at 15:03, xxxxxxxx wrote:
I had no problem with this code (generally the same for three dependent objects). Kept the handle from, well, flying off the handle. :)
// ObjectData.DetectHandle \> //\*---------------------------------------------------------------------------\* \> LONG MagnEtudeIPP_Zone::DetectHandle(PluginObject\* op, BaseDraw\* bd, LONG x, LONG y, LONG qualifier) \> //\*---------------------------------------------------------------------------\* \> { \> Matrix mg = op->GetMg(); \> \> if (bd->PointInRange(GetMEHandle(op,0L)\*mg,x,y)) return 0L; \> if (bd->PointInRange(GetMEHandle(op,1L)\*mg,x,y)) return 1L; \> \> return NOTOK; \> } \> // ObjectData.MoveHandle \> //\*---------------------------------------------------------------------------\* \> Bool MagnEtudeIPP_Zone::MoveHandle(PluginObject\* op, PluginObject\* undo, const Matrix& tm, LONG hit_id, LONG qualifier) \> //\*---------------------------------------------------------------------------\* \> { \> BaseContainer\* src = undo->GetDataInstance(); \> BaseContainer\* dst = op->GetDataInstance(); \> \> // Radius \> if (hit_id == 0L) \> { \> Real val = src->GetReal(MAGNETUDEIPP_ZONE_RADIUS)+(tm.off.x\*2.0f); \> dst->SetReal(MAGNETUDEIPP_ZONE_RADIUS, FCut(val,0.0f,(Real)MAXRANGE)); \> } \> // Transparency \> else if (hit_id == 1L) \> { \> Real val = src->GetReal(MAGNETUDEIPP_ZONE_TRANSPARENCY)+(tm.off.x\*0.01f); \> dst->SetReal(MAGNETUDEIPP_ZONE_TRANSPARENCY, FCut(val,0.0f,1.0f)); \> } \> return TRUE; \> } \> // MagnEtudeIPP_Zone.GetMEHandle \> //\*---------------------------------------------------------------------------\* \> Vector MagnEtudeIPP_Zone::GetMEHandle(PluginObject\* op, const LONG& id) \> //\*---------------------------------------------------------------------------\* \> { \> BaseContainer\* data = op->GetDataInstance(); \> if (data) \> { \> // Radius \> if (id == 0L) return Vector(data->GetReal(MAGNETUDEIPP_ZONE_RADIUS),0.0f,0.0f); \> // Transparency \> else if (id == 1L) return Vector(data->GetReal(MAGNETUDEIPP_ZONE_TRANSPARENCY)\*(data->GetReal(MAGNETUDEIPP_ZONE_RADIUS)\*0.9f),0.0f,0.0f); \> } \> return Vector(0.0f); \> } \>
On 25/08/2009 at 15:26, xxxxxxxx wrote:
Hm, damn, I guess one has to use the object "undo". Since my values are not stored in the Plugin object, but are in fact positions of the children, I can't use that.
Maybe I'll have to store all the children's positions in my PluginObject class, provide a Get function and access the original positions using that function.
I'll think about it :)
Thanks Robert!Cheers,
Jack
On 25/08/2009 at 16:26, xxxxxxxx wrote:
Strange, I can't get it to work...
I added some stuff to my class:
private: \> GeAutoDynamicArray<Vector>ChildPos; \> \> public: \> void SetChildPos(LONG index, Vector data) { this->ChildPos[index] = data; } \> Vector GetChildPos(LONG index) { return this->ChildPos[index]; } \>
In GetVirtualObjects() I fill the array with the child objects' positions.
In MoveHandle() I try the following:
\> Bool OSurfaceWire::MoveHandle(PluginObject \*op, PluginObject \*undo, const Matrix &tm;, LONG hit_id, LONG qualifier) \> { \> Vector val = tm.off; \> \> BaseObject \*pobj = GetSubObjByIndex(op, hit_id); \> \> // Get stored position from "undo" object \> // ->CRASH! \> Vector oldpos = ((OSurfaceWire\* )undo)->GetChildPos(hit_id); \> Vector newpos = Vector(); \> newpos.x = FCut(oldpos.x + tm.off.x, 0.0f, Len(oldpos)); \> newpos.y = FCut(oldpos.y + tm.off.y, 0.0f, Len(oldpos)); \> newpos.z = FCut(oldpos.z + tm.off.z, 0.0f, Len(oldpos)); \> \> if (pobj) pobj->SetPos(newpos); \> \> return TRUE; \> } \>
Since it crashes in the lined I marked, I thought I would maybe have to pass the private GeAutoDynamicArray in the CopyTo() function:
Bool OSurfaceWire::CopyTo(NodeData\* dest, GeListNode\* snode, GeListNode\* dnode, LONG flags, AliasTrans\* trn) \> { \> LONG size = sizeof(ChildPos); \> if(!(((OSurfaceWire\* )dest)->SplineMemory = (SplineObject\* )GeAlloc(size))) return FALSE; \> CopyMem(this->ChildPos, ((OSurfaceWire\* )dest)->ChildPos, size); \> return TRUE; \> } \>
The function is called, but it has no effect. MoveHandle() still crashes :-(
So, how can I apply the handle's movement to child objects of my plugin object?
Thanks again in advance!
Jack
On 25/08/2009 at 16:40, xxxxxxxx wrote:
By the way, little error in the code: Just ignore the 2nd line of the CopyTo function code.
On 26/08/2009 at 06:06, xxxxxxxx wrote:
I noticed my CopyTo code was rubbish, the array was not copied (all values were 0,0,0). Now I do it like this:
Bool OSurfaceWire::CopyTo(NodeData\* dest, GeListNode\* snode, GeListNode\* dnode, LONG flags, AliasTrans\* trn) \> { \> LONG n = ChildPos.GetCount(); \> LONG i = C_ZERO; \> \> while (i<=n) { \> ((OSurfaceWire\* )dest)->SetChildPos(i, ChildPos[i]); \> i++; \> } \> \> return TRUE; \> }
Now the array values are correctly copied into 'dest'.
Unfortunately, it seems to have nothing to do with the 'undo' object in MoveHandle(). Accessing it's GetChildPos/SetChildPos functions still crashes Cinema.
Please, any input?
Greetings,
Jack
