Hello @pim,
thank you for reaching out to us. First of all, there are two slightly ambiguous things about your question:
- You talk about the 'resolution from a material', which would be in the most sensible interpretation the preview size of a material, i.e., MATERIAL_PREVIEWSIZE, but the rest of your question rather implies that you want to know the dimensions of a bitmap file. I will answer the latter case.
- Your question also implies that every bitmap would carry its resolution in its metadata/header. That is not the case in the creative chaos that is bitmap file formats and their real-life implementations.
There is no straight answer to this, but:
- Bitmap metadata can be read with
BaseBitmap.GetData
, most fields are usually not set and there is no width or height field. See end of posting for an example.
- The type
BaseBitmap
is a wrapper for the maxon API type ImageInterface
. It is best to use ImageInterface
directly, but that is currently only possible in C++. There you also have more granular image metadata access.
- You claim 'that [it] takes time" to compute the width and height, but I do not see any indication for that. The computation seems efficient to me and operates on the memory layout of the bitmap.
- You could try to use something like pillow when you are unsatisfied with the speed of
BaseBitmap/ImageInterface
. But I doubt that this will be faster.
So, long story short: Just use the methods on BaseBitmap
. If there are any performance problems, I would ask you to provide example data and code, because I cannot see anything problematic here.
Code:
bmp: c4d.bitmaps.BaseBitmap = c4d.bitmaps.BaseBitmap()
res, _ = bmp.InitWith("e:\\misc\\particles.png")
if res != c4d.IMAGERESULT_OK:
print(f"{bmp.GetData(c4d.BASEBITMAP_DATA_GUIPIXELRATIO, None) = }")
print(f"{bmp.GetData(c4d.BASEBITMAP_DATA_DPI, None) = }")
print(f"{bmp.GetData(c4d.BASEBITMAP_DATA_ASPECTRATIO, None) = }")
print(f"{bmp.GetData(c4d.BASEBITMAP_DATA_EXPORTSETTINGS, None) = }")
print(f"{bmp.GetData(c4d.BASEBITMAP_DATA_NAME, None) = }")
c4d.bitmaps.ShowBitmap(bmp)
Result:
bmp.GetData(c4d.BASEBITMAP_DATA_GUIPIXELRATIO, None) = None
bmp.GetData(c4d.BASEBITMAP_DATA_DPI, None) = 72.0
bmp.GetData(c4d.BASEBITMAP_DATA_ASPECTRATIO, None) = 1.0
bmp.GetData(c4d.BASEBITMAP_DATA_EXPORTSETTINGS, None) = None
bmp.GetData(c4d.BASEBITMAP_DATA_NAME, None) = None
