Hi. I have some troubles with the example code on GitHub - PluginCafe that shows how to create a Repository using Python.
The code itself runs fine in R26 (R26.012 and R26.110), but results in an error in 2023.1.3.
Did something change from R26 to 2023 how a repository has to be created using CreateRepositoryFromUrl
or is that a problem with the python API? If it is a problem with the API is there a way around that?
The code:
def CreateRepositories():
"""Creates repositories for all user databases.
Doing this is usually not necessary for performing light- to medium-sized asset operations, and
the user preferences repository can then be used instead. Only when there is a substantial
amount of assets that must be processed, a repository should be constructed to limit the
search space for search operations. The method CreateRepositoryFromUrl() used in this example
can also be used to create a repository and its underlying database from scratch when the
provided URL points to location where no database has been established yet.
# Wait for all asset databases to be loaded, abort when this is not possible.
if not maxon.AssetDataBasesInterface.WaitForDatabaseLoading():
return RuntimeError("Could not load asset databases.")
# Get the default language of Cinema 4D (en-US) for retrieving the repository names.
defaultLanguage = maxon.Resource.GetDefaultLanguage()
# Iterate over all currently mounted databases and create an asset repository for each of them.
# Doing this is usually not necessary as user asset databases are automatically part of the
# the user preferences repository which is easier to retrieve. Creating a repository for a
# specific user asset database can be useful to speed up asset searches.
for database in maxon.AssetDataBasesInterface.GetDatabases():
# Create a unique identifier for the repository.
rid = maxon.AssetInterface.MakeUuid(str(database._dbUrl), True)
# Repositories can be composed out of other repositories which are called bases. In this
# case no bases are used to construct the repository. But with bases a repository for all
# user databases could be constructed for example.
bases = maxon.BaseArray(maxon.AssetRepositoryRef)
# Create a writable and persistent repository for the database URL. If #_dbUrl would point
# to a location where no database has been yet stored, the necessary data would be created.
repository = maxon.AssetInterface.CreateRepositoryFromUrl(
rid, bases, database._dbUrl, True, False, False)
if not repository:
raise RuntimeError("Repository construction failed.")
# Access some properties of the newly created repository.
repoId = repository.GetId()
isWriteable = repository.IsWritable()
name = repository.GetRepositoryName(defaultLanguage)
print(f"{repository} ({name}): id - {repoId}, writeable: {isWriteable}")
Error message I receive in C4D 2023:
Traceback (most recent call last):
File "scriptmanager", line 558, in <module>
File "scriptmanager", line 234, in CreateRepositories
File "C:\Program Files\Maxon Cinema 4D 2023\resource\modules\python\libs\python39\maxon\decorators.py", line 383, in Auto
ExecStaticMethod(*args)
TypeError: unable to convert builtins.NativePyData to @net.maxon.interface.class-cR
