Hi everyone, I'm writing a small ray tracer, and I'm having problems with the mesh indices, the order is wrong.
for(int i = 0;i < meshes.size();i++) { for (int k = 0; k < meshes[i].PolyCount;k++) { Int32 indexPointA = meshes[i].indices[k].a; Int32 indexPointB = meshes[i].indices[k].b; Int32 indexPointC = meshes[i].indices[k].c; Tri triangle; triangle.vertex0 = (meshes[i].vertices[indexPointA]) / 100.0f; triangle.vertex1 = (meshes[i].vertices[indexPointB]) / 100.0f; triangle.vertex2 = (meshes[i].vertices[indexPointC]) / 100.0f; IntersectTri(ray, triangle); if (ray.t < 1e30f) { _film->setImagePixel(x, y, 255, 255, 255); } } }
I'm using a plane (previously triangulated) to test and get this result:
i debuged the indices and they are wrong. indices: {1,3,0} - triangle 1 {1,2,3} - triangle 2
this is how i get the polygons:
void Scene::_recurseHierarchy(BaseObject* op) { while (op) { Bool isPolygon = op->IsInstanceOf(Opolygon) && !op->IsInstanceOf(Ojoint); if (isPolygon) { Frog::Mesh mesh = {}; GePrint(op->GetName()); PolygonObject* poly = (PolygonObject*)op; if (poly) { Int32 numOfVertices = poly->GetPointCount(); const CPolygon* cpoly = poly->GetPolygonR(); CPolygon* trianguled = nullptr; const Vector* vetices = poly->GetPointR(); Int32 trianguledPolyCount; Bool triRes = Triangulate(vetices, numOfVertices, &trianguled, &trianguledPolyCount); if (triRes) { mesh.vertices = vetices; mesh.indices = trianguled; mesh.PolyCount = trianguledPolyCount; objects.push_back(mesh); } } } _recurseHierarchy(op->GetDown()); op = op->GetNext(); } }
Can anyone point me what I'm doing wrong ?
Hi @fraukman2 thanks for posting, for me it's looks like a bug, since if you use a polygon primitive instead of a plane, it work as expected. I think there is a remapping needed for the point indices and polygon indices but I don't get it.
As it is the Christmas season, some members of the development team are away and the answer to this question may take longer than usual. But I will keep you posted as soon as I have more information.
In the meantime, the easiest way would be to use MCOMMAND_TRIAGULATE that will triangulate the passed object.
BaseObject* op = doc->GetActiveObject(); if (!op) return true; // This will triangle op, if you dont want to affect the object in the scene call GetClone first. PolygonObject* poly = static_cast<PolygonObject*>(op); ModelingCommandData mcd; mcd.op = op; if (!SendModelingCommand(MCOMMAND_TRIANGULATE, mcd)) return false; EventAdd(); return true;
Cheers, Maxime.
Hi @m_adam, I just tested your suggestion and worked flawless, thank you very much.
Cheers and happy holidays
