Hi guys, I'm curious if we have some guidance to show how to create/use "customgui_itemtree" UI as Volume Builder does it. I wish to make something simpler with checkbox+Enum UI as in picture at first. Any help please! Best, A.
I haven't used it as part of an object UI. So can't help there.
But for the usage of the treeview, you can just this thread https://plugincafe.maxon.net/topic/10654/14102_using-customgui-listview There's a working plug in there.
GeData objListData = GeData(CUSTOMDATA_ITEMTREE, DEFAULTVALUE); ItemTreeData* volList = (ItemTreeData*)(objListData.GetCustomDataType(CUSTOMDATA_ITEMTREE)); if (volList) volList->SetOwner((BaseList2D*)node); bc.SetData(ID_VOLUMEBUILDER_OBJECT_LIST, objListData);
this sets up the cgui_itemtree list. Important is to set the Owner, or many callbacks will not arrive the parent object.
It's recommended to refresh this owner on "MSG_DESCRIPTION_POSTSETPARAMETER" and "MSG_DOCUMENTINFO_TYPE_SETACTIVE"message, because it happens that the information is lost
#define BOOL_MODE_COLUMN ITEMTREE_USER_COL #define MIX_MODE_COLUMN ITEMTREE_USER_COL + 1 #define MIXVECTOR_MODE_COLUMN ITEMTREE_USER_COL + 2 #define CHILDTYPE_COLUMN ITEMTREE_USER_COL + 3 #define SMOOTH_RADIUS_COLUMN ITEMTREE_USER_COL + 4 BaseContainer* itreeui = description->GetParameterI(DescLevel(ID_VOLUMEBUILDER_OBJECT_LIST), arr); if (itreeui) { _volMode = GetVolumeMode(bc); BaseContainer userColTypes; userColTypes.SetInt32(BOOL_MODE_COLUMN, LV_DROPDOWN); userColTypes.SetInt32(MIX_MODE_COLUMN, LV_DROPDOWN); userColTypes.SetInt32(MIXVECTOR_MODE_COLUMN, LV_DROPDOWN); userColTypes.SetInt32(SMOOTH_RADIUS_COLUMN, LV_SLIDER); itreeui->SetContainer(ITEMTREE_USER_COL_TYPES, userColTypes); BaseContainer userColActive; userColActive.SetBool(BOOL_MODE_COLUMN, _volMode == VOLUMEMODE::SDF); userColActive.SetBool(MIX_MODE_COLUMN, _volMode == VOLUMEMODE::FOG); userColActive.SetBool(MIXVECTOR_MODE_COLUMN, _volMode == VOLUMEMODE::VECTOR); userColActive.SetBool(CHILDTYPE_COLUMN, true); userColActive.SetBool(SMOOTH_RADIUS_COLUMN, _volMode == VOLUMEMODE::SDF); itreeui->SetContainer(ITEMTREE_USER_COL_ACTIVE, userColActive); itreeui->SetBool(ITEMTREE_CHECKBOX_FRONT, true); BaseContainer thdata; thdata.SetString(ITEMTREE_ENABLE_COL, ""_s); thdata.SetString(ITEMTREE_OBJECT_COL, GeLoadString(IDS_VOLUMEBUILDERLIST_NAME)); thdata.SetString(BOOL_MODE_COLUMN, GeLoadString(IDS_VOLUMEBUILDERLIST_MODE)); thdata.SetString(MIX_MODE_COLUMN, GeLoadString(IDS_VOLUMEBUILDERLIST_MODE)); thdata.SetString(MIXVECTOR_MODE_COLUMN, GeLoadString(IDS_VOLUMEBUILDERLIST_MODE)); thdata.SetString(CHILDTYPE_COLUMN, GeLoadString(IDS_VOLUMEBUILDERLIST_INPUT_TYPE)); thdata.SetString(SMOOTH_RADIUS_COLUMN, GeLoadString(IDS_VOLUMEBUILDERLIST_SMOOTH_RADIUS)); itreeui->SetContainer(ITEMTREE_ID_HEADERS_DATA, thdata); BaseContainer thids; GeData columnId; columnId.SetInt32(CHILDTYPE_COLUMN); thids.SetData(CHILDTYPE_COLUMN, columnId); itreeui->SetContainer(ITEMTREE_ID_HEADERS_IDS, thids); }
thats the code in GetDDescription that sets up the UI with colums and header names and hides the columns that are not needed for the chosen mode.
Every entry needs the dropdown data in the list added (recommended to do that in the itemtree callback ITEMTREE_CALLBACK_INSERTNODE). Here an example how the volume builder does it:
inline BaseContainer BuildBoolCycleEntries() { BaseContainer cyclebc; cyclebc.InsData(ID_VOLUMEBUILDER_BOOL_UNION, GeLoadString(IDS_BOOL_UNION)); cyclebc.InsData(ID_VOLUMEBUILDER_BOOL_DIFF, GeLoadString(IDS_BOOL_DIFF)); cyclebc.InsData(ID_VOLUMEBUILDER_BOOL_INTERSECT, GeLoadString(IDS_BOOL_INTERSECT)); return cyclebc; } inline BaseContainer BuildBoolCycle() { BaseContainer bc; bc.SetContainer(DESC_CYCLE, BuildBoolCycleEntries()); return bc; } inline void AddDropdownDataToNode(ItemTreeNodeData& node) { BaseContainer cycleBoolBC = BuildBoolCycle(); cycleBoolBC.SetInt32(BOOL_MODE_COLUMN, ID_VOLUMEBUILDER_BOOL_UNION); BaseContainer cycleMixBC = BuildMixCycle(); cycleMixBC.SetInt32(MIX_MODE_COLUMN, ID_VOLUMEBUILDER_MIX_NORMAL); BaseContainer cycleMixVectorBC = BuildMixVectorCycle(); cycleMixVectorBC.SetInt32(MIXVECTOR_MODE_COLUMN, ID_VOLUMEBUILDER_MIXVECTOR_NORMAL); BaseContainer nodeContainer; nodeContainer.SetContainer(BOOL_MODE_COLUMN, cycleBoolBC); nodeContainer.SetContainer(MIX_MODE_COLUMN, cycleMixBC); nodeContainer.SetContainer(MIXVECTOR_MODE_COLUMN, cycleMixVectorBC); nodeContainer.SetString(CHILDTYPE_COLUMN, ""_s); node.m_Data.SetContainer(nodeContainer); }
in the resource file the UI element needs to be set up correctly:
ITEMTREE ID_VOLUMEBUILDER_OBJECT_LIST { ANIM ON; // animation is allowed NEWLINE; // the name of the UI element is above the ui element HEADERS; // shows the header bar MULTIPLE; // allows multiselect of entries COLUMNS 7; // amount of columns CHECKBOX; // checkbox added in the list FOLDERS; // parent folders can be created DRAGDROP; // drag & drop callbacks are send and d&d is allowed ICON; // entries are shown with icons NO_MENU; // no right click menu ACCEPT // what types are accepted in the list { Obase; 1001381; //TP GROUP } }
Hope this helps
Regards Fritz
Hey guys, Thanks for replies, I'll give some try as advice of Fritz at first. I definitely need it inside object UI, by C++
@khor
this is a bit old but I guess this can server as an additional resource https://c4dprogramming.wordpress.com/2012/11/25/treeview-made-simple-part-1/
@bentraje said in Info for ITEMTREE/customgui_itemtree:
@khor this is a bit old but I guess this can server as an additional resource https://c4dprogramming.wordpress.com/2012/11/25/treeview-made-simple-part-1/
Thanks, but it's not what I'm looking for!
Hi @Fritz, There are some missing bricks: definition for ItemTreeNodeData. I cannot find it in anywhere and how can we catch/register callbacks for itemtree to use ITEMTREE_CALLBACK_INSERTNODE?
Hi @khor unfortunately Fritz is in holiday, but from what I see this is not possible since few types are not public.
I will confirm with him when he will be back, in the meantime I wish you a nice Christmas. Cheers, Maxime.
