Is there an available commands for weight manager Load and Save Weights? I checked the documentation. I couldn't see any but I could be wrong.
I can use the c4d.CallCommand(1028186) # Save Weights... Works. But I'm trying to do it in batch. Select objects and save the all weights (i.e. TXT files) in one directory.
Currently, I have to do it one by one per object.
Is there a way around this?
this is not possible; you will get stuck with the dialog box asking where to save the result. But you can retrieve the joints and the Weight tag and save the data that are stored in the tags.
Cheers, Manuel
@manuel
Gotcha. Thanks for the confirmation. Closing this thread now.
