Unsolved Tags vanishing when Object is made Editable
Hello, I'm experiencing a difference between 2023 and 2023. If I add a Constraint tag to a Cube in both versions they behave differently when made Editable.
In 2023 when there is a Constraint tag and the Cube is made Editable the Constraint Tag remains on the now Polygon Object.
In 2023.1 when there is a Constraint tag and the Cube is made Editable the Constraint Tag disappears on the now Polygon Object.
I'm seeing the same behavior on one of my plugins, where is now disappears, and I don't know if this is a bug or something I need to solve for. Any idea what the cause of this would be?
Dan
I can confirm the issue with 2023.1. As you said, this is reproducible with the constraint tag so i would think that this is more a generic bug than just an API issue. You should contact our regular support for this.
That said, I tried it with our latest beta version, and it is already fixed. If i am right, you have access to our beta, so you should try it with your plugin to be sure it is also fixed.
Manuel
MAXON Registered Developer
Thanks Manuel,
I don't seem to have access to that level of the beta, but when I do I'll be sure to test it!
Dan
I checked it out and the issue is resolved!
Dan
cool, so you can mark this thread as resolved ^^
Manuel
