Is there a python equivalent of Reset Scale With Compensate Points
command?
Illustration of what it does:
- Supposing you have a point in 200cm (in xyz) with the polygon object at 100 (in xyz)
- If you reset scale with no compensate, the point will be at 2cm and polygon at 1 scale.
- But if you scale with compensate, the point will still be at 200cm and polygon at 1 scale, which is what I'm after.
P.S. There is an existing thread regarding the topic but its not resolved. Also its referring to a rig, which has complicated hierarchy. I'm only referring to ,
