I'm going to set a tree view as shown below. After adding items into the tree view for several times, it suddenly crashed in DrawText. This issue happens stably.
struct MyItem
enum
MATERIAL,
MESH,
CAMERA,
LIGTH
enum
OK,
WARNING,
ERROR
Int32 state = OK;
Int32 type = MATERIAL;
BaseList2D* element;
String parameter;
String problem;
struct MyItem
Int32 state = OK;
String parameter;
String problem;
struct MyItemNode
MyItem item; //data
MyItemNode* down = nullptr;
MyItemNode* next = nullptr;
using MyItemArray = maxon::BaseArray<MyItemNode>;
class MyTreeViewFunctions final : public TreeViewFunctions
void* m_selected_node = nullptr;
public:
static MyTreeViewFunctions& GetFunction()
static MyTreeViewFunctions func;
return func;
void* GetFirst(void* root, void* userdata) override
return static_cast<MyItemArray*>(root)->GetFirst();
void* GetDown(void* root, void* userdata, void* obj) override
return nullptr;
void* GetNext(void* root, void* userdata, void* obj) override
if (const auto node = static_cast<MyItemNode*>(obj))
return node->next;
return nullptr;
Bool IsSelected(void* root, void* userdata, void* obj) override
return m_selected_node == obj;
Int32 GetLineHeight(void* root, void* userdata, void* obj, Int32 col, GeUserArea* area) override
return 20;
Int32 GetColumnWidth(void* root, void* userdata, void* obj, Int32 col, GeUserArea* area) override
return 65;
void DrawCell(void* root, void* userdata, void* obj, const Int32 col, DrawInfo* drawinfo, const GeData& bgColor) override
if(!obj)
return;
const auto& item = static_cast<MyItemNode*>(obj)->item;
switch (col)
case MyDialog::LIST_COL_TYPE:
BaseBitmap* bm = nullptr;
switch (item.type)
case MyItem::MATERIAL:
bm = m_material_bitmap;
break;
case MyItem::MESH:
bm = m_mesh_bitmap;
break;
case MyItem::CAMERA:
bm = m_camera_bitmap;
break;
case MyItem::LIGTH:
bm = m_light_bitmap;
break;
default:;
drawinfo->frame->DrawBitmap(bm, drawinfo->xpos + drawinfo->width / 4, drawinfo->ypos + 2, ICON_SIZE, ICON_SIZE, 0, 0, bm->GetBw(), bm->GetBh(), BMP_NORMALSCALED);
break;
case MyDialog::LIST_COL_ELEMENT:
if (item.type == MyItem::MATERIAL)
if (auto* mat = reinterpret_cast<BaseMaterial*>(item.element); mat)
if (BaseBitmap* bm = mat->GetPreview(0); bm)
drawinfo->frame->DrawBitmap(bm, drawinfo->xpos, drawinfo->ypos + 2, ICON_SIZE, ICON_SIZE, 0, 0, bm->GetBw(), bm->GetBh(), BMP_NORMALSCALED);
drawinfo->frame->DrawSetTextCol(IsSelected(root, userdata, obj) ? COLOR_TEXT_SELECTED : COLOR_TEXT, COLOR_TRANS);
drawinfo->frame->DrawText(item.GetName(), drawinfo->xpos + ICON_SIZE + 2,drawinfo->ypos + drawinfo->height / 2, DRAWTEXT_VALIGN_CENTER);
break;
case MyDialog::LIST_COL_PARAMETER:
drawinfo->frame->DrawText(item.parameter, drawinfo->xpos + 2,
drawinfo->ypos + (drawinfo->height - drawinfo->frame->DrawGetFontHeight()) / 2 + 2);
break;
case MyDialog::LIST_COL_PROBLEM:
drawinfo->frame->DrawText(item.problem, drawinfo->xpos + 2, drawinfo->ypos + drawinfo->height / 2, DRAWTEXT_VALIGN_CENTER);
break;
default:;
Bool IsOpened(void* root, void* userdata, void* obj) override
return true;
String GetName(void* root, void* userdata, void* obj) override
return {};
Int GetId(void* root, void* userdata, void* obj) override
return 0;
Int32 GetDragType(void* root, void* userdata, void* obj) override
return NOTOK;
void Select(void* root, void* userdata, void* obj, Int32 mode) override
if(mode == SELECTION_SUB)
else
m_selected_node = obj;
