Hello @bentraje,
Thank you for reaching out to us.
FindChild
takes an Id or node kind as its argument, ...texturesampler.tex0
is a valid node ID for the Redshift Texture node, ...texturesampler.tex0.colorspace
is not, there is simply no such node.
The Filename (com.redshift3d.redshift4c4d.nodes.core.texturesampler.tex0
) in-port of the Redshift Texture node is a port bundle, i.e., is a port that has child-ports. Its child port Color Space for example, has simply the ID colorspace
and its Path child port the ID path
I guess you want to save some vertical script space, the things you can do are:
- Just write it into one chained instruction:
colorSpaceOutPort = node.GetInputs().FindChild("com.redshift3d.redshift4c4d.nodes.core.texturesampler.tex0").FindChild("colorspace")
- Use
maxon.GraphModelHelper.ListAllNodess
to retrieve all nodes in a graph that are have the ID colorspace
. This will indeed list all nodes that have that ID, and GraphModelHelper
was not available in R25.
- Use node paths, node paths sort of do what you want to be done. A node path is represented by the type NodePathInterface. There are multiple methods in the Nodes API which operate on node paths, the relevant for your use case would be GraphModelInterface.GetNode. But Node paths are not easy to construct by hand, as they must uniquely identify anything in a graph, so, when you have two
Texture>Filename>Color Space
node-trees in your graph, a node path must disambiguate them. There is also GraphNode.FindInnerNode
which takes a relative node path as an argument, so you can index ports from a (true) node with it.
I personally would not do any of this. The Nodes API can produce code that is longer than one is comfortable with, this is true. But if you start condensing your code to extreme levels of abstraction, you won't be able to read any of it six months later (the "when I wrote this, only God and I knew what it meant, now only God knows"-effect). Be verbose in your code, especially when an API is complex, this is the best thing you can do for readability and maintainability.
We are aware of the problems of the Nodes API, and that especially technical artist type users wish for easier interfaces, "to just plug things together". But the Nodes API effectively implements a modern graph database model which is inherently complex. So, it is at least not easy to do this, without nullifying everything the Nodes API want to achieve: A strong abstraction of a scene/material graph. As indicated by GraphModelHelper
, we are already working on this, but the Nodes API will probably be never as straight forward as a classic API scene graph was, simply because it is much more abstract.
What also plays into this, is that maxon attributes for Redshift IDs have not been exposed. It makes a big difference if you have to write node.GetInputs().FindChild("com.redshift3d.redshift4c4d.nodes.core.texturesampler.tex0")
or if you can write node.GetInputs().FindChild(maxon.redshift.texturesampler.filename)
, but the C++ maxon attributes which would be necessary for this to trickle down to Python do not yet exist. I am lobbying for this since R25, but the Redshift team never got to it, next time we will talk, I will bug them again about this
