Freeing Loaded BaseDocument
    On 27/08/2003 at 18:25, xxxxxxxx wrote:
    Cinema 4D Version:   8.100
    Platform:      Mac OSX  ;
    I'm writing a file-animation plugin (ie one which loads a different file per frame), and everything works fine until I try to free the document I've loaded.
    I've tried using BaseDocument::Free() and also ::KillDocument(), but both crash C4D.
    Here's the relevant bit of code:
    class FileAnim : public ObjectData
    BaseDocument* _anidoc; // initted to 0 in FileAnim()
    BaseObject*
    FileAnim::GetVirtualObjects(PluginObject* op, HierarchyHelp* hh)
    Filename filenm;
    // cache not valid: must load new file
    if (_anidoc)
          // HELP! both of these will crash us!
          ::KillDocument(_anidoc);
          BaseDocument::Free(_anidoc);
    _anidoc = ::LoadDocument(filenm, true /*showerrors*/);
    return _anidoc->GetFirstObject();
    How should I be freeing the loaded document?
    Thanks.
    .angus.
    On 28/08/2003 at 00:46, xxxxxxxx wrote:
    You should remove the objects from the document before passing them from GetVirtualObjects(), then from your document. Only the first object and all children will be passed out using that method btw.
    On 28/08/2003 at 18:23, xxxxxxxx wrote:
    Thanks David.
    Now looks something like the following and works a treat.
    // cache invalid
    BaseDocument* anidoc = ::LoadDocument(filenm, true /*showerrors*/);
    BaseObject* aniroot = BaseObject::Alloc(Onull);
    BaseObject* obj = anidoc->GetFirstObject();
    for ( ; obj; obj = obj->GetNext())
          obj->Remove();    // remove from anidoc
          obj->InsertUnderLast(aniroot);
    BaseDocument::Free(anidoc);
    return aniroot;
    .angus.
