Hi Experts,
I´m trying to develop a little python script that imports Substance Textures, creates Redshift materials and connects all the right textures.
But i'm having a hard time figuring out how to edit parameters on nodes.
Example: I inserts a texture node with the following code:
textureNode = graph.AddChild('', maxon.Id("com.redshift3d.redshift4c4d.nodes.core.texturesampler"), maxon.DataDictionary())
That works like a champ, and i can easily wire in/out ports.
But how do i change the values in the "Texture node" i just created? (Path to texture, Color Space, etc)
Looking forward to hear from you guys
I had occasion to do this recently and it's all explained in the Redshift Renderer section of the SDK documentation. Basically, you access the port and set its default value. There's an extra step for adding a bitmap to a texture node, but it's the same principle.
Steve
Hello
Here is my little Redshift api helper on Github , it have a AddTexture function to do this .
AddTexture
It is a bare-bone one , and I have no time to perfection , but it can work for basic for now
It has a little example , welcome to improve it and have fun
Hope it can help for anyway .
@spedler Thanks mate, using fictive input ports did the trick @Dunhou Wauw, that's a great Custom API, this makes it soooo much easier. Thanks a bunch Dunhou
Hi @sortsovs once you have the node, you need to retrieve the appropriate port. Be careful as some port can be nested. Then once you have the correct port, you need to call GraphNode.SetDefaultValue. When calling SetDefaultValue it is important to pass a maxon data as the current Python system is not able to automatically guess the expected result.
SetDefaultValue
Find bellow an example to create a Redshift Material with a Texture Node with a custom path and name.
import c4d import maxon REDSHIFT_NODESPACE_ID = maxon.Id("com.redshift3d.redshift4c4d.class.nodespace") def CreateTextureNode(gr: maxon.GraphModelRef, nodeName: str, texturePath: str, isLinear:bool=False) -> maxon.GraphNode: # Start a transaction to inform the graph that a modification is going to happen with gr.BeginTransaction() as transaction: # Create a Redshift Texture Node and rename it textureNodeId = maxon.Id("com.redshift3d.redshift4c4d.nodes.core.texturesampler") texNode = gr.AddChild("", textureNodeId, maxon.DataDictionary()) texNode.SetValue("net.maxon.node.base.name", maxon.String(nodeName)) # Retrieve path and gammage override port path = texNode.GetInputs().FindChild("com.redshift3d.redshift4c4d.nodes.core.texturesampler.tex0").FindChild("path") gammaOverride = texNode.GetInputs().FindChild("com.redshift3d.redshift4c4d.nodes.core.texturesampler.tex0_gammaoverride") # Define the value stored by the node for these port when no connection exist gammaOverride.SetDefaultValue(maxon.Bool(isLinear)) path.SetDefaultValue(maxon.Url(texturePath)) # Push the change to the graph transaction.Commit() return texNode def main() -> None: # Create a BaseMaterial in the active document rsMat = c4d.BaseMaterial(c4d.Mmaterial) doc.InsertMaterial(rsMat) # Retrieve it node material part and create a Redshift Graph nMat = rsMat.GetNodeMaterialReference() nMat.AddGraph(REDSHIFT_NODESPACE_ID) gr = nMat.GetGraph(REDSHIFT_NODESPACE_ID) # Create a texture node albedoTexNode = CreateTextureNode(gr, "Albedo", r"C:/PathToATexture.jpg") c4d.EventAdd() if __name__ == '__main__': main()
Cheers, Maxime.
