I asked this a few years ago (six years ago, actually) but I ask again, because there is a solution now (I hope). Is there any way, in Python, to force the display in the editor of the strength of a Vertex Map, actually, showing what would be shown if a Vertex Map was active, but without having to click the Vertex Map itself?
Hello @rui_mac,
Thank you for reaching out to us. It depends on what you then considered to be a valid answer and what not. Generally speaking, the answer is no, not much has changed there. Vertex maps only draw their content when selected. Some bits and bytes for Python:
BIT_ACTIVE
NBIT_OHIDE
Vertex maps are not something where you can change the behavior, e.g., make them draw themselves even when not selected. This also applies to C++, but you have a few more options there:
CustomDataTag
VariableTag
VertexMapTag
Cheers, Ferdinand
The file: vertexmap_example.c4d The result: The code:
"""Draws a vertex map attached to the same object into the viewport. """ import c4d doc: c4d.documents.BaseDocument # The document evaluating this tag op: c4d.BaseTag # The Python scripting tag def main() -> None: """Called by Cinema 4D to execute the Python tag, not used in this example. """ pass def draw(bd: c4d.BaseDraw) -> bool: """Called by Cinema 4D to let the tag draw into view ports. """ # We could also limit this to specific view ports to ensure at least some performance ... cam: c4d.CameraObject = bd.GetSceneCamera(bd.GetDocument()) name: str = bd.GetName() # Evaluate the camera of the vp or its name to bail on drawing ... # Bail when this is not the object draw pass if bd.GetDrawPass() != c4d.DRAWPASS_OBJECT: return # Get the object the Python tag is attached to. node: c4d.PolygonObject = op.GetMain() if not isinstance(node, c4d.PolygonObject): return # Find its first vertex map. vertexMapTag: c4d.VariableTag = node.GetTag(c4d.Tvertexmap) if vertexMapTag is None: return # Get the vertex map weights and the point and polygon data. data: list[float] = vertexMapTag.GetAllHighlevelData() points: list[c4d.Vector] = node.GetAllPoints() polygons: list[c4d.CPolygon] = node.GetAllPolygons() # Define a little lambda to convert [0, 1] weight values into yellow-red gradient as the # vertex map tag does. f: callable = lambda v: c4d.Vector( 1, c4d.utils.RangeMap(v, 0, 1, 0, 1, True), 0 ) # Setup the drawing space to the object space of #node and draw over polygons (offset 5). bd.SetMatrix_Matrix(node, node.GetMg(), zoffset=5) # Draw all polygons in #node manually, yikes, not fast :) for poly in polygons: bd.DrawPolygon( [points[poly.a], points[poly.b], points[poly.c], points[poly.d]], [f(data[poly.a]), f(data[poly.b]),f(data[poly.c]),f(data[poly.d])] ) return True
Thank you so much, @ferdinand . The second option seems like the best one for me, if at all possible. My plugin is already a tag. So, is there any way to have the plugin selected, showing all the parameters in the Attributes Manager, and, at the same time, have a hidden VertexMap tag that shows the yellow-red gradient on the object where my plugin tag is active?
Just implemented it but the problem is that when I turn the hidden tag active, the Attribute Manager tells me that there are two objects selected (Multiple Objects) and the parameters of my plugin tag are no longer displayed. Is there any way to keep both the hidden VertexMap tag and my plugin tag active, and display the parameters of my plugin tag in the Attribute Manager?
The only "solution", so far, is to manually activate the plugin tag, lock the Attribute Manager, and then activate the VertexMap tag. Not an ideal "solution"
Hello Remo,
Thank you for your updates,
@rui_mac said in Force VertexMap display:
I am not quite sure how you mean that, but I assume the underlying issue is here that I was not verbose enough in how at least I would implement that: You must constantly write from a source tag (or any other data source, does not have to be a vertex map) into a hidden vertex map and make sure that it stays selected.
I do not have any problems implementing this, including having the plugin interface being shown in the Attribute Manger, or just generally poking around in the tag selection state of the object. Find a quick example below.
If this was not what you meant, could you please restate what is going wrong for you? On a side note: We are exploiting here Cinema 4D behavior in an unintended manner, so this hack is not officially supported.
The file: tag_shenenigans.c4d The result: The code:
"""Constantly copies over the data from a source vertex map to a hidden vertex map. This can be used to mimic manually drawing a vertex map. You could even extend this to draw the union, intersection, difference, etc. of multiple tags. This quick and dirty solution will not flood an object with dozens of tags by locking onto a unique ID on that hidden tag, but when the Python tag is removed, the hidden tag will linger. A more practical solution would be to implement this as a TagData plugin where one could clean up after oneself when the tag is being moved or deleted. """ import c4d import typing doc: c4d.documents.BaseDocument # The document evaluating this tag op: c4d.BaseTag # The Python scripting tag # An ID to identify a hidden vertex map tag that has been crated for the purpose of this Python # tag. We need this so that we can reestablish the linkage between this Python tag and a driver # without flooding a scene/object with these hidden drawing tags. The better solution would be to # bind the lifetime of such drawing tag to the lifetime of a TagData plugin tag, but we cannot # do this here. ID_VM_DRAWTAG: int = 1060040 def GetDrawTag(node: c4d.PolygonObject) -> typing.Tuple[c4d.VariableTag, c4d.VariableTag]: """Retrieves or creates the hidden drawing tag of a polygon object. """ # We loop over all tags on #node. tag: c4d.BaseTag = node.GetFirstTag() while isinstance(tag, c4d.BaseTag): # There usually will be at least two vertex map tags #node, the source and the hidden # drawing tag. We need a safe way to identify such hidden drawing tag which is ours. # For that we use C4DAtom.AddUniqueID/FindUniqueID to mark such tags via ID_VM_DRAWTAG as # ours. if tag.CheckType(c4d.Tvertexmap): # Try to get the ID_VM_DRAWTAG UUID on a Tvertexmap tag. mem: typing.Optional[memoryview] = tag.FindUniqueID(ID_VM_DRAWTAG) # This overly cautious, but technically someone could have accidentally also written # to that ID, so we check if the stored data is indeed #True. When this is the case, # we have found the draw tag and return it. if isinstance(mem, memoryview): data: bytes = bytes(mem) try: if bool(data) == True: return tag except: print ("Stepping over unexpected UUID data.") # Continue tag iteration on #node. tag = tag.GetNext() # When we have reached this line, it means there is no #ID_VM_DRAWTAG Tvertexmap tag on #node. # We create a new tag with the size of node, hide the tag and insert it under #node and then # return that new tag. tag: c4d.VariableTag = c4d.VariableTag(c4d.Tvertexmap, node.GetPointCount()) if not isinstance(tag, c4d.BaseTag): raise MemoryError("Could not allocate vertex map tag.") tag.AddUniqueID(ID_VM_DRAWTAG, bytes(True)) tag.ChangeNBit(c4d.NBIT_OHIDE, True) node.InsertTag(tag) return tag def main() -> None: """Called by Cinema 4D to execute the Python tag. """ # Get the data source vertex map from the user data. Again, this code is a bit overly cautious, # and expects the user data access to fail. try: sourceTag: c4d.VariableTag = op[c4d.ID_USERDATA, 1] if (not isinstance(sourceTag, c4d.VariableTag)) or (sourceTag.GetType() != c4d.Tvertexmap): return except: return # Get the polygon object the Python tag is attached to. node: c4d.PolygonObject = op.GetMain() if not isinstance(node, c4d.PolygonObject): return # Create or get the hidden "DrawTag" and bail when the source and draw tag do not match in size. drawTag: c4d.VariableTag = GetDrawTag(node) if sourceTag.GetDataCount() != drawTag.GetDataCount(): return # Copy the data and make sure the hidden drawing tag is still selected. drawTag.SetAllHighlevelData(sourceTag.GetAllHighlevelData()) drawTag.SetBit(c4d.BIT_ACTIVE)
@ferdinand,
When I tried to implement this, as soon as I do the tag.ChangeNBit(c4d.NBIT_OHIDE, True) thing, the Attribute Manager changes to show the attributes of the VertexMap tag, and the parameters of my plugin tag, that create the hidden VertexMap tag disapear. I'm at work now, but I will recheck my code agaisnt yours, later. Thank you so much.
@rui_mac
You should not do this on an already inserted tag, the code I am showing above is as lined out very much in a grey area, or to be a bit more blunt, is a giant threading restriction violation. You should refrain from modifying the scene graph from outside of the main thread as much as you can, as this can introduce everything between odd behavior to outright crashes.
But I would say the singular insertion of the vertex map tag is somewhat safe. When you run into problems, you must defer all scene graph modifications, i.e., the insertion of that hidden tag, to the main thread. By for example using NodeData::Message to carry out something that before has been lined up by TagData::Execute.
NodeData::Message
TagData::Execute
I was creating the hidden VertexMap in the Init method of my plugin tag. But my main problem, like I described, was that activating the hidden VertexMap tag would show the VertexMap parameters in the Attribute Manager, instead of the parameters of my plugin tag.
Hey @rui_mac,
I assume you mean here that the tag node was made the "active object" of the Attribute Manager, i.e., it had the same effect as if you called c4d.gui.ActiveObjectManager_SetObject on the hidden tag? This could be a side-effect of 'misbehaving' in a threaded environment, I assume you are in TagData::Execute, but it seems unlikely. Could you please share an executable example of your code, because otherwise it will be very hard for me to help you.
@ferdinand, here is a version of my code with all the stuff that is not important for this problem, removed. Although, I fully commented everything I removed. I hope it is enough to spot the problem.
import c4d import os import sys import math import random from c4d import gui,plugins,bitmaps,documents,utils,Matrix,BaseContainer from c4d import threading PLUGIN_ID = 1037312 CHECK_ID = 1037275 PLUGIN_NAME ="VertexMapMix" PLUGIN_VERSION = "1.1" url_access = "vertexmapmix" # define the IDs of the interface elements VMM_ONOFF = 1000 VMM_VERTEXMAP = 1001 VMM_ATOMS = 1002 VMM_CREATEVERTEXTAG = 1003 VMM_SELECTVERTEXTAG = 1004 VMM_ATOM_ONOFF = 2001 VMM_ATOM_MIX = 2002 VMM_ATOM_INVERT = 2003 VMM_ATOM_SELECT = 2004 VMM_ATOM_NAME = 2005 VMM_ATOM_OPACITY = 2006 VMM_ATOM_BLUR = 2007 VMM_REMAPPING = 2020 VMM_ATOM_CURVE = 2021 VMM_SHOW = 2025 VMM_MIX_NORMAL = 0 VMM_MIX_MULT = 1 VMM_MIX_MIN = 2 VMM_MIX_MAX = 3 VMM_MIX_ADD = 4 VMM_MIX_SUB = 5 icon_edit = c4d.bitmaps.BaseBitmap() # ******************************************************************************* class vertex_mm(plugins.TagData): old_selection = 0 old_pressed = -1 old_show = 1 def Init(self,node): # in here I initialize all the GUI elements # ... # and in here I create the hidden VertexMap tag op = node.GetMain() if not isinstance(op, c4d.PolygonObject): return True tags = op.GetTags() hidden_tag = None for tag in tags: if tag[c4d.ID_BASELIST_NAME] == "vmm_hidden": hidden_tag = tag break if hidden_tag == None: pnum=op.GetPointCount() hidden_tag=c4d.VariableTag(c4d.Tvertexmap,pnum) op.InsertTag(hidden_tag) hidden_tag[c4d.ID_BASELIST_NAME]="vmm_hidden" hidden_tag.ChangeNBit(c4d.NBIT_OHIDE,True) return True # ******************************************************************************* def Message(self,node,type,data): if node==None: return True # this code would turn the display of the VertexMap values on or off, # depending on the state of a checkbok if type==c4d.MSG_DESCRIPTION_VALIDATE: state = node[VMM_SHOW] if state != self.old_show: self.old_show = state op = node.GetObject() if op.GetType() != 5100: return True tags = op.GetTags() hidden_tag = None for tag in tags: if tag[c4d.ID_BASELIST_NAME] == "vmm_hidden": hidden_tag = tag break if hidden_tag == None: pnum=op.GetPointCount() hidden_tag=c4d.VariableTag(c4d.Tvertexmap,pnum) op.InsertTag(hidden_tag) hidden_tag[c4d.ID_BASELIST_NAME]="vmm_hidden" hidden_tag.ChangeNBit(c4d.NBIT_OHIDE,True) if state == 1: hidden_tag.SetBit(c4d.BIT_ACTIVE) op.SetBit(c4d.BIT_ACTIVE) op.Message(c4d.MSG_UPDATE) else: hidden_tag.DelBit(c4d.BIT_ACTIVE) return True # ******************************************************************************* def Execute(self,tag,doc,op,bt,priority,flags): # here I do all the stuff that the plugin is supposed to do # at the end, in the list called w_array1, are all the values # to store in the hidden VertexMap tag, for display tags = op.GetTags() hidden_tag = None for tag in tags: if tag[c4d.ID_BASELIST_NAME] == "vmm_hidden": hidden_tag = tag break if hidden_tag != None: hidden_tag.SetAllHighlevelData(w_array1) vertex_mix.SetAllHighlevelData(w_array1) # the "vertex_mix" is a visible VertexMap tag, where the values are also stored. # IMPORTANT!!! # if it would be possible to make the VertexMap shading appear, simply by using # this visible VertexMap tag, I would be more than fine with this. # The problem, so far, is that I have to click this visible tag to make the # shading appear, and that makes all the parameters of my plugin Tag disapear # from the Attribute Manager. op.Message(c4d.MSG_UPDATE) return c4d.EXECUTIONRESULT_OK # ******************************************************************************* # registration of the tag if __name__=="__main__": # Register the Tag icon = c4d.bitmaps.BaseBitmap() dir, file = os.path.split(__file__) icon.InitWith(os.path.join(dir, "res", "icon_vmm.tif")) icon_edit.InitWith(os.path.join(dir, "res", "edit.tif")) c4d.gui.RegisterIcon(1037349,icon_edit) plugins.RegisterTagPlugin(id=PLUGIN_ID, str=PLUGIN_NAME, g=vertex_mm, description="vertexmapmix", icon=icon, info=c4d.TAG_EXPRESSION|c4d.TAG_VISIBLE|c4d.TAG_MULTIPLE) print("["+PLUGIN_NAME+" Tag - v"+PLUGIN_VERSION+"] by Rui Batista: Loaded")
I will have a look tomorrow; I was busy today.
So, I had a look at your code. It was unfortunately not executable in this form, even when I filled in some gaps like adding the necessary resources or re-indenting stuff. So, I cannot say many concrete things here, and only look at the general form.
I must also point out again, that this is a hack and not officially supported. If you chose to take this route instead of drawing the data yourself, possible side effects will be up to you to handle.
Message
Init
TagData
if it would be possible to make the VertexMap shading appear, simply by using this visible VertexMap tag, I would be more than fine with this.
It would be the same, just iterate over the tags of the node hosting your tag and select whatever tags you want to select.
The result: The plugin: pc14184.zip
The pyp file of the plugin:
"""Implements a tag which manages a hidden vertex map to draw data. """ import c4d import typing class VertexMapMixData(c4d.plugins.TagData): """Implements a tag which manages a hidden vertex map to draw data. """ PLUGIN_ID: int = 1037312 DRAWTAG_ID: int = 1060040 PLUGIN_NAME: str = "VertexMapMix" PLUGIN_DESCRIPTION: str = "Tvertexmapmix" def __init__(self) -> None: """Initializes the instance, specifically its _hiddenDrawTags lookup table. """ self._hiddenDrawTags: dict[bytes: c4d.BaseTag] = {} super().__init__() def FlushHiddenTags(self, node: c4d.GeListNode) -> None: """Flushes the #_hiddenDrawTags cache and removes all the hidden tags from the hosting node. """ host: typing.Optional[c4d.BaseObject] = node.GetMain() if not isinstance(host, c4d.BaseObject): return tag: c4d.BaseTag for tag in host.GetTags(): if tag.GetType() != c4d.Tvertexmap: continue # This is a hidden drawing tag instance. uuid: typing.Optional[memoryview] = tag.FindUniqueID(VertexMapMixData.DRAWTAG_ID) if isinstance(uuid, memoryview): tag.Remove() self._hiddenDrawTags = {} def GetHiddenDrawTag(self, node: c4d.PolygonObject) -> typing.Optional[c4d.VariableTag]: """Retrieves the hidden drawing tag on a polygon object. """ # Bail when #node is not a polygon object or not attached to a document. if (not isinstance(node, c4d.PolygonObject) or not isinstance(node.GetDocument(), c4d.documents.BaseDocument)): return None # Get the UUID of the polygon object so that we look up its hidden tag in the lookup. uuid: typing.Optional[memoryview] = node.FindUniqueID(c4d.MAXON_CREATOR_ID) if not isinstance(uuid, memoryview): return None # Check if there is already a cached hidden draw tag in dictionary of the plugin interface. hiddenTag: typing.Optional[c4d.BaseTag] = self._hiddenDrawTags.get(bytes(uuid), None) if isinstance(hiddenTag, c4d.BaseTag) and hiddenTag.IsAlive(): return hiddenTag # Just for verbosity here to make clear that this can still return None. return None def SetHiddenDrawTag(self, node: c4d.BaseTag) -> None: """Creates the hidden drawing tag on a polygon object. """ # The host is not a polygon object or there is already a valid drawing tag on that host. if (not isinstance(node, c4d.PolygonObject) or isinstance(self.GetHiddenDrawTag(node), c4d.VariableTag)): return # Flush the cache to remove any lingering tags and get the UUID of the polygon object so # that we cache the hidden draw tags. self.FlushHiddenTags(node) hostUuid: typing.Optional[memoryview] = node.FindUniqueID(c4d.MAXON_CREATOR_ID) if not isinstance(hostUuid, memoryview): return # Start creating the new tag, for that we must be on the main thread. if not c4d.threading.GeIsMainThread(): return tag: c4d.VariableTag = c4d.VariableTag(c4d.Tvertexmap, node.GetPointCount()) if not isinstance(tag, c4d.BaseTag): raise MemoryError("Could not allocate vertex map tag.") tag.AddUniqueID(VertexMapMixData.DRAWTAG_ID, bytes(True)) tag.ChangeNBit(c4d.NBIT_OHIDE, True) node.InsertTag(tag) # Put the tag in the lookup table. self._hiddenDrawTags[bytes(hostUuid)] = tag def Init(self, node: c4d.GeListNode) -> bool: """Called by Cinema 4D to initialize the node. """ self.InitAttr(node, c4d.BaseList2D, c4d.ID_SOURCE_DATA) self.InitAttr(node, bool, c4d.ID_DRAW_DATA) node[c4d.ID_SOURCE_DATA] = None node[c4d.ID_DRAW_DATA] = True # Attempt to create the tag, as all methods, Init is not guaranteed to be on the main thread. self.SetHiddenDrawTag(node.GetMain()) return True def Free(self, node: c4d.GeListNode) -> None: """Called by Cinema 4D when the node is about to be destroyed. Will remove all hidden tags on the node. """ self.FlushHiddenTags(node) def CopyTo(self, dest: c4d.plugins.NodeData, snode: c4d.GeListNode, dnode: c4d.GeListNode, flags: int, trn: c4d.AliasTrans) -> bool: """Called by Cinema 4D when a tag is being copied. Will remove all hidden tags on the source node, so that when a user drag-and_drops the tag from object A to object B, object A is being cleaned up. """ self.FlushHiddenTags(snode) return True def Message(self, node: c4d.GeListNode, type: int, data: object) -> bool: """Called by Cinema 4D to send messages to the node. We just use this here as something that is called often on the main thread. But there is no guarantee that this will run on the main thread, you were sending yourself a message, MSG_UPDATE, to a node outside of the main thread in your TagData::Execute. Never assume Message to run on the main thread only. """ # Try to create the tag, could be throttled by picking a specific message ID which is # called often enough. self.SetHiddenDrawTag(node.GetMain()) return True def Execute(self, tag: c4d.BaseTag, doc: c4d.documents.BaseDocument, op: c4d.BaseObject, bt: c4d.threading.BaseThread, priority: int, flags: int) -> int: """Called by Cinema 4D to execute the tag. """ state: bool = tag[c4d.ID_DRAW_DATA] src: typing.Optional[c4d.VariableTag] = tag[c4d.ID_SOURCE_DATA] dst: typing.Optional[c4d.VariableTag] = self.GetHiddenDrawTag(op) # There is no source or destination tag we could write from or to. if not isinstance(src, c4d.VariableTag) or not isinstance(dst, c4d.VariableTag): return c4d.EXECUTIONRESULT_OK # Select or deselect the hidden tag. if tag[c4d.ID_DRAW_DATA]: dst.SetBit(c4d.BIT_ACTIVE) else: dst.DelBit(c4d.BIT_ACTIVE) # Determine of we should copy the data and then copy the data. if (src.GetType() != dst.GetType() or src.GetDataCount() != dst.GetDataCount()): return c4d.EXECUTIONRESULT_OK dst.SetAllHighlevelData(src.GetAllHighlevelData()) return c4d.EXECUTIONRESULT_OK def RegisterPlugin() -> None: """Registers the plugin. """ if not c4d.plugins.RegisterTagPlugin( id=VertexMapMixData.PLUGIN_ID, str=VertexMapMixData.PLUGIN_NAME, g=VertexMapMixData, description=VertexMapMixData.PLUGIN_DESCRIPTION, icon=c4d.bitmaps.InitResourceBitmap(c4d.FLgradient), info=c4d.TAG_EXPRESSION | c4d.TAG_VISIBLE | c4d.TAG_MULTIPLE): raise RuntimeError(f"Failed to register: {VertexMapMixData}") if __name__ == "__main__": RegisterPlugin()
@ferdinand, thank you for the excellent advices. I hope I can get home soon enough after work to clean up my code according to your advices and implement your solution. Also, your advices will allow me to clean up some of my other plugins. Thank you very much, once again.
Well, it kind of works. When I adjust parameters in the plugin tag, sometimes the Attribute Manager reverts to show "2 Elements [VertexMap,ThePluginName]" I even tried with your plugin and, by twirling the Data Source parameter open and, for example, turning the Invert option on, the Attribute Manager stops showing the plugin parameters, and starts showing "2 Elements [VertexMap,VertexMapMax]"
ah, okay, I understand what you mean. Yeah, that is a bit odd and also makes this solution not very viable. As I said before, this always was a hack. When I did this myself a few years ago, I think I never ran into this issue.
The underlying problem here is that the Attribute Manager is able to display a hidden tag as selected and the whole setup relies on the fact that hidden tags are being ignored in that context. It is also very erratic how this happens, when I for example click long enough on the Draw Data bool, the problem will also occur at some point and at the same time, it sometimes it does not happen 'inside' the vertexmap when I change a parameter there.
Since this seems to be tied to parameter writing events, you could try to switch off the hidden tag being selected before a parameter is being written and turn it back on after that. But that will become really complicated or even possible to do for 'buried' parameters changes, such as for example, changing something in a field driving a vertex map which is linked in the tag.
I will file this as a bug because the Attribute Manager should not be able to display hidden tags in single or multi-selections. In the meantime, I can only recommend using C++ and drawing things yourself or using CustomDataTagDisplayInterface, as this will be performant and is also guaranteed to work.
@ferdinand, thank you for the answer and explanation. I will try to find a compromise. In the meanwhile, one can always select the tag, lock the Attribute Manager and click the VertexMap tag to display the result. Cumbersome, but it works.
