working on something in python, and i'm trying to create some if statements depending on whether AOV's are Enabled or Disabled. The Command Line tells me to use "Redshift[c4d.REDSHIFT_RENDERER_AOV_GLOBAL_MODE]" but this only returns "None" regardless of whether it's enabled or disabled. How do I access this data?
Thank you
Please mark your thread as a question using the forum tools.
Redshift is a VideoPostData plugin. You cannot access the parameter directly in the renderdata. This is just a guess of what you are trying to do.
Instead, you must find the VideoPostData that contain all Redshift parameters.
from typing import Optional import c4d import redshift doc: c4d.documents.BaseDocument # The active document op: Optional[c4d.BaseObject] # The active object, None if unselected def main() -> None: renderdata = doc.GetActiveRenderData() vprs = redshift.FindAddVideoPost(renderdata, redshift.VPrsrenderer) if vprs is None: raise ValueError("Cannot find the redshift VideoPostData") print (vprs[c4d.REDSHIFT_RENDERER_AOV_GLOBAL_MODE]) if __name__ == '__main__': main()
There is this thread where you will find a script to print all the AOVs
Cheers, Manuel
