How can I update the deformer like the "Spline" deformer when I move the objects in the viewport?
My splines for my deformer plugin are in the "c4d.InExcludeData" like the below.
I know that the callback function "Draw(self, op, drawpass, bd, bh)" is about the viewport.
But I don't know how to update the deformer when I move the spline objects or its affected polygon objects in the viewport.
My updated contents is same as the callback fuction "ModifyObject(self, mod, doc, op, op_mg, mod_mg, lod, flags, thread)".
Hello @LingZA,
Thank you for reaching out to us. This topic has been assigned to me, but I was busy with the Maxon developer interviews and release preparations. Your issue is the next thing on my desk.
Cheers, Ferdinand
Hello @lingza,
Thank you for reaching out to us. There are in principle two ways how you can do this:
InExcludeData
ObjectData.CheckDirty
The result:
The code:
def CheckDirty(self, op: c4d.BaseObject, doc: c4d.documents.BaseDocument) -> None: """Called by Cinema 4D to let a modifier flag itself as dirty. Args: op: The object representing the modifier hook. doc: The document containing the modifier. """ # When we want to track dependencies we must keep a cache for what we consider to be the # last no-dirty state of things. This could be done in many ways, I have chosen here a # dict of (bytes, int) tuples. # # The general idea is to store the last known dirty state data for each item in the # InExcludeData as such: # # { Object_A: 193, Object_B: 176, Object_C: 25, ...} # # But BaseList2d instances itself are not hashable, i.e., cannot be keys in a dict, and # doing something like `myDict[id(someObject)] = someValue` would be a really bad idea, # as objects are managed in the backend by Cinema 4D and can be reallocated all the time, # so id(myBaseList2d) is not a safe way to identify objects. Instead we are using # C4DAtom.FindUniqueID to get the unique MAXON_CREATOR_ID marker of each item and then # use that marker to store the dirty flags. # The dirty cache data structure attached to the plugin class and the InExcludeData parameter # in question. self._linklistDirtyCache: dict[bytes: int] data: c4d.InExcludeData = op[c4d.ID_LINKLIST] if not isinstance(data, c4d.InExcludeData): return # Now we iterate over all items in the InExcludeData to see if their dirty state has changed. isDirty: bool = False for i in range(data.GetObjectCount()): node: c4d.BaseList2D = data.ObjectFromIndex(doc, i) if not isinstance(node, c4d.BaseList2D): continue # Get the MAXON_CREATOR_ID unique ID of this node. mem: memoryview = node.FindUniqueID(c4d.MAXON_CREATOR_ID) if not isinstance(mem, memoryview): continue uuid: bytes = bytes(mem) # Get the current and cached dirty state of that item. currentDirtyCount: int = node.GetDirty(c4d.DIRTYFLAGS_DATA | c4d.DIRTYFLAGS_MATRIX) cachedDirtyCount: typing.Optional[int] = self._linklistDirtyCache.get(uuid, None) # When there is either no cache or the cache differs from the current value, we update # our cache and set isDirty to True. if (currentDirtyCount is None) or (cachedDirtyCount != currentDirtyCount): isDirty = True self._linklistDirtyCache[uuid] = currentDirtyCount # When isDirty is True, we flag ourselves as dirty, which will cause ModifyObject to be called. if isDirty: op.SetDirty(c4d.DIRTYFLAGS_DATA) print (f"Modifier has been set dependency dirty: {self._linklistDirtyCache.values()}")
