Hello :
In Short : Failed to remove a shortcut with python like : remove Shift + 1 for move camera and add it to my own tool .
Shift + 1
More Descriptions : I am trying to remove a C4D shortcut and add it to my own tools , but it didn't work in my plugins : I want my tool has 4 shortcut , like :
Ctrl + 1
#-------------------------------------------------------------------- # Plugin Class #-------------------------------------------------------------------- ### ========== Execute ========== ### #? 缓存灯光 class CacheLight(LightSolo): def __init__(self) -> None: pass # Override - Called when the plugin is selected by the user. def Execute(self, doc=c4d.documents.BaseDocument): self.CacheState() return True #? 重置灯光 class ResetLight(LightSolo): def __init__(self) -> None: pass # Override - Called when the plugin is selected by the user. def Execute(self, doc=c4d.documents.BaseDocument): alllights = self.getAllLights() for light in alllights: self.ResetState(light) # 重置灯光 return True #? 灯光组solo class SoloLightGroup(LightSolo): def __init__(self) -> None: pass # Override - Called when the plugin is selected by the user. def Execute(self, doc=c4d.documents.BaseDocument): self.SoloLightGroup() # 灯光组solo return True #? 灯光solo class SoloLights(LightSolo): def __init__(self) -> None: pass # Override - Called when the plugin is selected by the user. def Execute(self, doc=c4d.documents.BaseDocument): self.SoloLights() # 灯光solo return True #-------------------------------------------------------------------- # Shortcut. #-------------------------------------------------------------------- def RemoveShortcut(qualifier,key): """ Remove Shortcut by given qualifier and key Args: qualifier (int): modifier key key (int): ascii code of key """ for x in range(c4d.gui.GetShortcutCount()): shortcutBc = c4d.gui.GetShortcut(x) # Check if shortcut is stored in the basecontainer. if shortcutBc[0] == qualifier and shortcutBc[1] == key: index = x try: c4d.gui.RemoveShortcut(index) except: print ("Shortcut {} remove failed".format(c4d.gui.Shortcut2String(qualifier, key))) return False def AddShortCut(qualifier,key,pluginID): """ Add Shortcut by given qualifier and key to given ID Args: qualifier (int): modifier key key (int): ascii code of key pluginID (int): plugin ID """ for x in range(c4d.gui.GetShortcutCount()): shortcutBc = c4d.gui.GetShortcut(x) # Check if shortcut is stored in the basecontainer. if shortcutBc[0] == qualifier and shortcutBc[1] == key: if shortcutBc[c4d.SHORTCUT_PLUGINID] == pluginID: print ("Shortcut {} is already Used for Command ID: {}".format(c4d.gui.Shortcut2String(qualifier, key), shortcutBc[c4d.SHORTCUT_PLUGINID])) return # Define shortcut container bc = c4d.BaseContainer() bc.SetInt32(c4d.SHORTCUT_PLUGINID, pluginID) bc.SetLong(c4d.SHORTCUT_ADDRESS, 0) bc.SetLong(c4d.SHORTCUT_OPTIONMODE, 0) # User defined key bc.SetLong(0, qualifier) bc.SetLong(1, key) return c4d.gui.AddShortcut(bc) ### ========== Register Plugin ========== ### if __name__ == "__main__": key = 49 # num 1 next ~ # remove shortcut reg with Cinema 4D for [move camera] RemoveShortcut(7,key) RemoveShortcut(4,key) RemoveShortcut(1,key) RemoveShortcut(3,key) # Add own shortcut AddShortCut(7,key,SUB_PLUNIGID_CACHE) AddShortCut(4,key,SUB_PLUNIGID_SOLOG) AddShortCut(1,key,PLUNIGID) AddShortCut(3,key,SUB_PLUNIGID_RESET) c4d.EventAdd() # Plugins Register iconfile = c4d.bitmaps.BaseBitmap() iconfile.InitWith(ICONPATH) c4d.plugins.RegisterCommandPlugin( id = SUB_PLUNIGID_CACHE, str = PLUNGINNAME + "Cache State", info = c4d.PLUGINFLAG_HIDEPLUGINMENU, # hide help = "Cache All Light Objects State", dat = CacheLight(), icon = iconfile ) c4d.plugins.RegisterCommandPlugin( id = SUB_PLUNIGID_RESET, str = PLUNGINNAME + "Reset State", info = c4d.PLUGINFLAG_HIDEPLUGINMENU, # hide help = "Reset All Light Objects State", dat = ResetLight(), icon = iconfile ) c4d.plugins.RegisterCommandPlugin( id = SUB_PLUNIGID_SOLOG, str = PLUNGINNAME + "Solo Group", info = 0, # c4d.PLUGINFLAG_COMMAND_STICKY, help = "Solo Selected Light Objects in Group", dat = SoloLightGroup(), icon = iconfile ) c4d.plugins.RegisterCommandPlugin( id = PLUNIGID, str = TITLE, info = c4d.PLUGINFLAG_HIDEPLUGINMENU, # hide help = INFO, dat = SoloLights(), icon = iconfile )
Hello @dunhou,
Thank you for reaching out to us, and thank you for the clear posting, much appreciated. There are multiple reasons why removing shortcuts does not work in your example.
index
RemoveShortcut(int, int)
if shortcutBc[0] == qualifier and shortcutBc[1] == key: index = x # You define #index only here. try: # Will raise an AttributeError for 'index' when the condition above never ran. c4d.gui.RemoveShortcut(index) except: ...
Find a commented example of your RemoveShortcut at the end of the posting. I turned off the actual removal of shortcuts in the example so that running it will not break your Cinema 4D. We might also add a small example and some other documentation to our SDK for shortcuts, because currently the makeup of a shortcut container is not too well documented.
RemoveShortcut
Cheers, Ferdinand
The output:
RemoveShortcut([c4d.QUALIFIER_SHIFT, '1']) = 4 RemoveShortcut([c4d.QUALIFIER_CTRL, c4d.QUALIFIER_SHIFT, '1']) = 434 RemoveShortcut(['M', 'S']) = 194 RemoveShortcut([c4d.QUALIFIER_CTRL, 'A']) = 53 RemoveShortcut([c4d.QUALIFIER_CTRL, 'A'], managerId=nodeEditorManager) = 390 RemoveShortcut([c4d.QUALIFIER_CTRL, 'A'], pluginId=nodeEditorSelectAllNodes) = 390
The code:
"""Demonstrates how to find and remove shortcuts in Cinema 4D. Shortcuts are tied to how Cinema 4D internally handles sequences of key strokes (called input events in Cinema 4D). The example showcases besides the general data structures with which these events are communicated ways to disambiguate shortcuts for different input contexts, e.g., pressing 'CTRL + A' in the object manager and 'CTRL + A' in the node editor. I have commented out the actual removing of shortcuts int the example, so that the example can be run without 'bricking' a Cinema 4D installation. The example is also unable to handle mouse key shortcuts, e.g., SHIFT + ALT + LMB. It would be entirely possible to do this, but I have fashioned RemoveShortcut() and how it interprets its #keySequence argument in such way that this is not possible, because it distinguishes qualifier inputs from value inputs by type. One would have to simply make the #keySequence data structure a bit more complex to also support mouse buttons. """ import typing import c4d def RemoveShortcut(keySequence: list[typing.Union[int, str]], managerId: typing.Optional[int] = None, pluginId: typing.Optional[int] = None) -> bool: """ Finds a shortcut index by the given #keySequence and optionally #managerId and/or #pluginId. I have commented out the actual removing of shortcuts int the example, so that the example can be run without 'bricking' a Cinema 4D installation. Args: keySequence: A sequence of keyboard inputs, e.g., [c4d.QUALIFIER_SHIFT, '1']. managerId (optional): The manager context of the shortcut to find or remove. pluginId (optional): The plugin ID of the plugin invoked by the shortcut. Returns: The success of the removal operation. Raises: RuntimeError: On illegal key symbols. RuntimeError: On non-existing shortcut key sequences. """ # The input data #keySequence is fashioned in a user friendly way, e.g., # # [c4d.QUALIFIER_SHIFT, c4d.QUALIFIER_ALT, "S", "T"] # # for the shortcut SHIFT + ALT + S ~ T. We must bring this into a form which what aligns how # such data is handled internally. # # 1. All qualifiers are ORed together. # 2. There can be multiple successive stroke events, e.g., M ~ S. # The raw values of the input are, # # [1, 4, "S", "T"] # # which are being transformed into this: # # [ (5, 83), # (qualifier = 1 | 4 = 5, key = ASCII_VALUE("S")) # (0, 84) # (qualifier = 0 , key = ASCII_VALUE("T") # ] # The list of key stroke modifier-key tuples. strokeData: list[tuple[int, int]] = [] # A variable to OR together the qualifiers for the current key stroke. currentModifiers: int = 0 for key in keySequence: # Extend a modifier key sequence, e.g., SHIFT + ALT + CTRL if isinstance(key, (int, float)): currentModifiers |= key # A character key was found, append an input event. elif isinstance(key, str) and len(key) == 1: strokeData.append((currentModifiers, ord(key.upper()))) currentModifiers = 0 # Something else was found, yikes :) else: raise RuntimeError(f"Found illegal key symbol: {key}") # Now we can iterate over all shortcuts in Cinema 4D. for index in range(c4d.gui.GetShortcutCount()): # Get the shortcut at #index. bc: c4d.BaseContainer = c4d.gui.GetShortcut(index) # The shortcut container #bc is structured as follows: # # Container Access ID Description # bc[0] 0 Qualifier sequence of the first key stroke. # bc[1] 1 ASCII value of the first key stroke. # bc[10] 10 Qualifier sequence of the second key stroke (optional). # bc[11] 11 ASCII value of the second key stroke (optional). # [...] # bc[990] 990 Qualifier sequence of the 99th key stroke (optional). # bc[991] 991 ASCII value of the 99th key stroke (optional). # bc[c4d.SHORTCUT_PLUGINID] 1000 The plugin id of the thing triggered by the shortcut. # bc[c4d.SHORTCUT_ADDRESS] 1001 The the manager context of the shortcut. # bc[c4d.SHORTCUT_OPTIONMODE] 1002 If the shortcut opens the plugins options dialog. # # So, for multi keystroke events, e.g., A ~ B, the strokes are being placed with a stride # of 10 between the container indices [0, 990]. Also placed in this stride is qualifier OR # sum for each stroke. Here is the content of two real life containers for clarity: # # A container for pressing the key "0"(48). There are no qualifiers here. # # 0: 0 # 1: 48 # 1000: 200000084 # 1001: 0 # 1002: 0 # # A container for pressing "M"(77) and then "S"(83). There are no qualifiers here. # # 0: 0 # 1: 77 # 10: 0 # 11: 83 # 1000: 431000015 # 1001: 0 # 1002: 0 # We test if #strokeData matches #bc. isMatch: bool = True for i, (qualifier, key) in enumerate(strokeData): idQualifier: int = i * 10 + 0 idKey: int = i * 10 + 1 # A qualifier + key stroke did not match, we break out. if bc[idQualifier] != qualifier or bc[idKey] != key: isMatch = False break # Something in the key sequence did not match with #strokeData, so we try the next shortcut # container provided by the outer loop. if not isMatch: continue # We could do here some additional tests, as shortcut key strokes do not have to be unique, # i.e., there could be two short-cuts "Shift + 1" bound to different manager contexts. if pluginId is not None and bc[c4d.SHORTCUT_PLUGINID] != pluginId: continue if managerId is not None and bc[c4d.SHORTCUT_ADDRESS] != managerId: continue # All tests succeeded, the shortcut at the current index should be removed, we instead just # return the index to make this example a bit less volatile. # return c4d.gui.RemoveShortcut(index) return index # All shortcuts have been traversed and no match was found, the user provided a key sequence # which is not a shortcut. raise RuntimeError(f"The shortcut sequence {keySequence} was not found.") def main() -> None: """Runs the example. """ # Remove/find the shortcut index for "Shift + 1" print (f"{RemoveShortcut([c4d.QUALIFIER_SHIFT, '1']) = }") # Remove/find the shortcut index for "Shift + Alt + 1" print (f"{RemoveShortcut([c4d.QUALIFIER_CTRL, c4d.QUALIFIER_SHIFT, '1']) = }") # Remove/find the shortcut index for "M ~ S" print (f"{RemoveShortcut(['M', 'S']) = }") # To filter duplicate shortcuts, either the manager context or plugin ID must be used. Most plugin # IDs are public, but all most no manager IDs are public. The only way to figure them out is to # reverse engineer the GetShortcut() containers. nodeEditorManager: int = 465002211 # The ID of the node editor manager. nodeEditorSelectAllNodes: int = 465002309 # The plugin ID of the "Select All" (nodes) command. # Remove/find the shortcut index for "CTR + A". There are multiple shortcuts for this sequence, # this will return the first match. print (f"{RemoveShortcut([c4d.QUALIFIER_CTRL, 'A']) = }") # Remove/find the shortcut index for "CTR + A" in the Node Editor context. print (f"{RemoveShortcut([c4d.QUALIFIER_CTRL, 'A'], managerId=nodeEditorManager) = }") # Remove/find the shortcut index for "CTR + A" which invokes the plugin with the ID 465002309. print (f"{RemoveShortcut([c4d.QUALIFIER_CTRL, 'A'], pluginId=nodeEditorSelectAllNodes) = }") if __name__ == "__main__": main()
@ferdinand Thank you for detailed explain . It's great to add a shortcut container document update and small examples , actually , more examples on sdk or Github is really helpful.
After reading I try to re-write it and add some functions like add shortcut or check plugin's shortcut list, It's all worked as expected . Shortcut BaseContainer explain is that great to move on .
By the way , from those examples , I learned and try to keep code style as easy to read and repair like yours at the same time . So much appreciated.
