Is there any way to get the render information in picture viewer, mainly the render time? The purpose is to visualize the time taken to render each frame in a graph, to determine the average render time, etc.
I would like to know if it is possible in python, c++ only, or neither. Any help would be greatly appreciated!
Hello @kng_ito,
Thank you for reaching out to us. No, that is not possible, the Picture Viewer is as all managers not being exposed in our APIs.
However, there are three other paths you could take:
MSG_MULTI_RENDERNOTIFICATION
TagData
ScenHookData
VideoPostData
Cheers, Ferdinand
The scene file: track_render.c4d An example output:
Rendering for <c4d.documents.BaseDocument object called with ID 110059 at 2502775112192> finished: 0.07 sec. Rendering for <c4d.documents.BaseDocument object called with ID 110059 at 2502775084928> finished: 0.071 sec. Rendering for <c4d.documents.BaseDocument object called with ID 110059 at 2502775152000> finished: 0.066 sec. Rendering for <c4d.documents.BaseDocument object called with ID 110059 at 2502775139200> finished: 4.443 sec.
The code:
"""Example for measuring the time of renderings with the help of MSG_MULTI_RENDERNOTIFICATION. This solution here is flawed in to ways: 1. Python Programming tag modules, e.g., the content of this file, can be volatile. Cinema 4D can 'forget' its content/state until it is time to call it again. Which means you cannot store anything in this module. I am solving this here by injecting data into the sys module. Which is not a very nice thing to do, boo on me I guess :) We could also inject data into the document, which would be a bit nicer, but also not really good. This should be solved properly with a TagData plugin (C++/Python) or better a SceneHookData plugin (C++) as there we can attach our data to the plugin. 2. You are inherently unable to track frames of a rendering with MSG_MULTI_RENDERNOTIFICATION, as the message is only being sent for the start and end of a rendering. To solve this you must pick other solutions as using Team Render or implementing this as a VideoPostData plugin (C++ only). """ import c4d import sys import typing import time # Some messages which can be printed. MSG_MALFORMED_DATA: str = "Stepping over malformed render notification data." MSG_HASH_COLLISION: str = ("Rendering for the document is already being tracked. " "Cannot track more than one rendering per document.") MSG_UNTRACKED_RENDERING: str = "An untracked rendering has finished, no time information available." MSG_RENDER_TIME: str = "Rendering for {} finished: {} sec." # The name of the attribute which we are going to attach to #sys (to store our data) ID_DATA_CONTAINER: str = "c4d_render_data" def main() -> None: """The tag does nothing on execution. """ pass def message(mid: int, data: object) -> bool: """Called by Cinema 4D to propagate messages to nodes. """ # This is a message for a rendering being started or closed. if mid == c4d.MSG_MULTI_RENDERNOTIFICATION: # The message data are in some shape or form malformed. if not isinstance(data, dict): print (MSG_MALFORMED_DATA) return True # True for the start of a rendering, False for the end. isStart: bool = data.get("start", None) # The render document. renderDoc: c4d.documents.BaseDocument = data.get("doc", None) if None in (isStart, renderDoc): print (MSG_MALFORMED_DATA) return True # We could attach the render document to sys, but that would be a REALLY bad idea. So, we # are going to identify the renderings/render documents via their UUID. renderUUID: typing.Optional[memoryview] = renderDoc.FindUniqueID(c4d.MAXON_CREATOR_ID) if renderUUID is None: print (MSG_MALFORMED_DATA) return True # Since we want to insert the UUID into a dict (hashmap) we must make it hashable by casting # it to bytes. renderHash: bytes = bytes(renderUUID) # Get our makeshift data container attached to #sys or attach one when there is none. The # container looks like this: # # { # bytes_hash: start_of_rednering_in_unix_epoche_time, # ..., # bytes_hash: start_of_rednering_in_unix_epoche_time # } # # But it will only contain ongoing renderings. So, usually there will only be one # rendering in it. dataContainer: dict = getattr(sys, ID_DATA_CONTAINER, None) if dataContainer is None: dataContainer = {} setattr(sys, ID_DATA_CONTAINER, dataContainer) # Is true when #renderDoc, its hash, is in #dataContainer. isTracked: bool = isinstance(dataContainer.get(renderHash, None), bytes) # A second rendering has been started for this document, we won't have any of this and just # skip it. With some finesse it would be possible to solve this, but I did not here. This # can only track one rendering per document. if isStart and isTracked: print (MSG_HASH_COLLISION) # A rendering hash finished where we did not witness its start. Spooky :) elif not isStart and isTracked: print (MSG_UNTRACKED_RENDERING) # A rendering has been started. We put the start time under the document hash into our data # container. elif isStart: dataContainer[renderHash] = time.time() # A rendering has finished. We get its stating time from the data container, report the # time difference and remove the item from the data container. elif not isStart: tRender: int = time.time() - dataContainer[renderHash] print (MSG_RENDER_TIME.format(renderDoc, round(tRender, 3))) dataContainer.pop(renderHash) return True
Hi @ferdinand,
Thank you as always for your detailed answer and even the sample scene file! It seems like a lot of work with my current level of understanding, but your answer is a great hint.
I'll try to do a little research on my own. Thank you very much.
