Sorry, my English is not very good. Maybe I can't describe my problem very well. I am currently learning to make a simple plug-in. I hope to select a point, click a button, and create a selection tag. This step has been completed, but I hope to automatically link to my linkbox when creating a tag (I have an "addcustomgui_linkbox"). thank!
Bool MatrixAlignDialog::CreateLayout() { SetTitle("Matrix Align"_s); GroupBegin(0, BFV_SCALEFIT | BFH_SCALEFIT, 2, 0, "Select Object"_s, 0); { GroupBorderSpace(5, 5, 5, 5); GroupBorder(BORDER_GROUP_IN); AddStaticText(IDC_LINKBOX1_TEXT, BFH_RIGHT | BFH_FIT, 100, 20, "Object"_s, 0); AddCustomGui(IDC_LINKBOX1, CUSTOMGUI_LINKBOX, String(), BFH_SCALEFIT, 250, 10, BaseContainer()); } GroupEnd(); GroupBegin(0, BFV_SCALEFIT | BFH_SCALEFIT, 3, 0, "Set Start Group"_s, 0); { GroupBorderSpace(5, 5, 5, 5); GroupBorder(BORDER_GROUP_IN); AddButton(IDC_BUTTON1, BFH_SCALEFIT, 150, 20, "Set Point"_s); AddStaticText(IDC_LINKBOX2_TEXT, BFH_RIGHT | BFH_FIT, 100, 20, "Start Group"_s, 0); AddCustomGui(IDC_LINKBOX2, CUSTOMGUI_LINKBOX, String(), BFH_SCALEFIT, 250,10, BaseContainer()); } GroupEnd(); GroupBegin(0, BFV_SCALEFIT | BFH_SCALEFIT, 3, 0, "Set End Group"_s, 0); { GroupBorderSpace(5, 5, 5, 5); GroupBorder(BORDER_GROUP_IN); AddButton(IDC_BUTTON2, BFH_SCALEFIT, 150, 20, "Set Point"_s); AddStaticText(IDC_LINKBOX3_TEXT, BFH_RIGHT | BFH_FIT, 100, 20, "End Group"_s, 0); AddCustomGui(IDC_LINKBOX3, CUSTOMGUI_LINKBOX, String(), BFH_SCALEFIT, 250, 10, BaseContainer()); } GroupEnd(); GroupBegin(0, BFV_SCALEFIT | BFH_SCALEFIT, 3, 0, ""_s, 0); { GroupBorderSpace(5, 5, 5, 5); GroupBorder(BORDER_GROUP_IN); AddButton(IDC_BUTTON3, BFH_SCALEFIT, 150, 20, "Reset Pivot"_s); } GroupEnd(); return true; } Bool MatrixAlignDialog::Command(Int32 id, const BaseContainer& msg) { switch (id) { case IDC_BUTTON1: { // run the code for IDC_BUTTON1 const Int32 commandID = 12552; if(IsCommandEnabled(commandID)) { CallCommand(commandID); } break; } case IDC_BUTTON2: { // run the code for IDC_BUTTON2 const Int32 commandID = 12552; if (IsCommandEnabled(commandID)) { CallCommand(commandID); } break; } case IDC_LINKBOX2: { // get point selection tag break; } default: { break; } } return true;
perfectly clear
you need to retrieve the gadget itself to update it:
GeDialog
You need to create the selection tag:
I tried both methods but i would create the selection tag myself.
witch (id) { case IDC_BUTTON1: { // run the code for IDC_BUTTON1 /* // First solution const Int32 commandID = 12552; if (IsCommandEnabled(commandID)) { CallCommand(commandID); LinkBoxGui* linkGui = static_cast<LinkBoxGui*>(FindCustomGui(IDC_LINKBOX2, CUSTOMGUI_LINKBOX)); if (linkGui == nullptr) return false; BaseDocument* doc = GetActiveDocument(); if (doc == nullptr) return false; BaseList2D* selectionTag = (BaseList2D*)doc->GetActiveTag(); if (selectionTag == nullptr) return false; return linkGui->SetLink(selectionTag); } */ BaseDocument* doc = GetActiveDocument(); if (doc == nullptr) return false; BaseObject* op = doc->GetActiveObject(); if (op == nullptr) return false; BaseSelect* bs = ToPoly(op)->GetPointS(); if (bs == nullptr) return false; SelectionTag* selectionTag = (SelectionTag*)op->MakeTag(Tpointselection); BaseSelect* selectionFromTag = selectionTag->GetBaseSelect(); bs->CopyTo(selectionFromTag); // Instead of searching for the custom gadget, a pointer could be stored in the dialog class // and defined when the gadget is added in the CreateLayout function. LinkBoxGui* linkGui = static_cast<LinkBoxGui*>(FindCustomGui(IDC_LINKBOX2, CUSTOMGUI_LINKBOX)); if (linkGui == nullptr) return false; EventAdd(); // Instead of returning the result of the SetLink function, one should test if it did not failed // and reverse the tag creation if it did. return linkGui->SetLink(selectionTag); break; } case IDC_LINKBOX2: { // get point selection tag LinkBoxGui* linkGui = static_cast<LinkBoxGui*>(FindCustomGui(IDC_LINKBOX2, CUSTOMGUI_LINKBOX)); if (linkGui == nullptr) return false; BaseDocument* doc = GetActiveDocument(); if (doc == nullptr) return false; SelectionTag* selectionTag = (SelectionTag*)linkGui->GetLink(doc); if (selectionTag == nullptr) ApplicationOutput("the field is empty"); return true; break; } }
Cheers, Manuel
@m_magalhaes Oh, no, I'm really excited. Thank you very much. I'm looking at my code in your way now
@m_magalhaes thank you so much,you and your code is perfact
