Hello! We have an OBJECT_MODIFIER plugin which already works fine, but with one minor problem. When you enable render region, it's just black. The plugin modifies an object, but render region turns black the moment you add the plugin to a scene, even when it has no object to modify. Did someone encounter this before or has any clues where to look at in the code?
Hello @danchyg1337,
Thank you for reaching out to us. Your question is unfortunately not answerable in its current form as there can be dozens of reasons for why this is happening, and without a more precise description of the problem and source code we will only be guessing.
With that being said, there are two things I would check:
ModifyObject
Cheers, Ferdinand
Hello! Sorry for not providing any specific info about the problem, it was not really aything to provide in fact. Your last guess about document related stuff is absolutely correct. There is a piece of code responsible for handling a license which was indeed using documents. Thanks!
