I use houdini to create and export some abc file to c4d. But I found that when the abc file is loading in c4d, it can not be delete or overwrite? I have to restart c4d(due to octane render, it is really slow when reopen an existing project). Is there a script to release the abc file so that I can overwrite it?
Hello @atticuslv,
as indicated in my last posting, this is not a programming question, as you do not invoke any of our APIs, and you should reach out to customer support with that question. We only deliver API related support here.
Cheers, Ferdinand
While in principle a simple enough question, I struggle here a bit with the tense you used and the lack of some other information.
Some thoughts:
All in all, this sounds more like an end-user support problem or a bug than a programming problem. We cannot provide end-user-support in this forum. I would recommend reaching out to end-user support by opening a ticket and asking your question there.
OK, I will go to fill in some details. I am using R26 on windows11. What I said is once I create a abc file, and load it in a c4d scene(just like your image, I successfully load it as an abc object), I cannot write a new version of file to this path unless I close c4d. So every I want to check the shading of a new abc file, I will follow the step.
