Hi guys! Is it possible to convert string value to BaseTime with this function?
Converts a string to a data value of type float, int or c4d.BaseTime.
>>> c4d.utils.StringToNumber('11', c4d.FORMAT_FRAMES, doc.GetFps()) 11.0 >>> c4d.utils.StringToNumber('11', c4d.FORMAT_SECONDS, doc.GetFps()) 11.0 >>> c4d.utils.StringToNumber(11, c4d.FORMAT_FRAMES, doc.GetFps()) 11.0
After some tests i had no luck with it.️
>>> doc[c4d.DOCUMENT_MINTIME] = c4d.utils.StringToNumber('11', c4d.FORMAT_FRAMES, doc.GetFps()) Traceback (most recent call last): File "console", line 1, in <module> TypeError: __setitem__ expected c4d.BaseTime, not float >>>
Thank you!
Hello @mikeudin,
thank you for reaching out to us. I had a look at the C++ backend and the statement you quoted does not seem to be true (anymore). The cases FORMAT_FRAMES, FORMAT_SECONDS and FORMAT_SMPTE all return a float value. So, both the Python and C++ documentation are not correct. I will add a task to fix these issues.
FORMAT_FRAMES
FORMAT_SECONDS
FORMAT_SMPTE
float
It is not 100% clear to me what you were trying to achieve, but I think this is what you want to do:
>>> import c4d >>> value = "11" # This call does not make much sense IMHO. One could just use int() or float() # to convert a frame value expressed by a string into a numeric value. >>> c4d.utils.StringToNumber('11', c4d.FORMAT_FRAMES, doc.GetFps()) 11.0 >>> int(value) 11 # Convert a frame-value to a value in seconds for a given document. A BaseTime value is # document independent, a value in frames is not, we must provide the FPS. >>> t = int(value) / doc.GetFps() >>> doc.GetFps() 30 >>> t 0.36666666666666664 # Pack the value into a BaseTime >>> bt = c4d.BaseTime(t) >>> bt <c4d.BaseTime object at 0x000001C2B9D3E6C0> >>> bt.Get() 0.367
If you simply want to set the document's min time, why not just do this:
doc[c4d.DOCUMENT_MINTIME] = c4d.BaseTime(11)
If you simply want to set the document's min time, why not just do this ...
Well, the question is what that value is supposed to be. Judging from the context I assumed it to be a value in frames and not seconds. Your BaseTime would be equal to frame 330 for a document with 30 FPS. And also, the input is meant to be a string.
Oh, ok. I assumed he just wanted to set the document min time and didn't know a better way to get a BaseTime than using StringToNumber.
Great, thank you guys!
