i am trying to read the data from a drag and drop event on a tag but the "data" seem to contain a thing called a "capsule object" that i don't know how to crack in to
also from the looks of it the "msg" should contain the "INPUT_QUALIFIER" to limit the main function to only run when the "drop" part of the drag happens but i cant seem to work that out ether
any one have any experience in this stuff?
Hello @jesse,
Thank you for reaching out to us. It is always best to be as precise as possible with questions. I assume you are talking about MSG_DRAGANDDROP and its data input argument being of type PyCapsule? A PyCapsule is a wrapper type for arguments from the C/C++ backend of Python. Such value is effectively meaningless in Python and mostly intended to be passed through. You cannot 'crack into' it.
MSG_DRAGANDDROP
data
PyCapsule
It would be best if you would describe:
Otherwise, it will be extremely hard for us to give you a precise answer.
Cheers, Ferdinand
