I want copy point position(World) & paste to Other Object's Point(World). The coordinate manager can displays the World-Position values. but there is no copy paste function. You can use the Snap function of C4D, but I want to reduce even one click.
I want to create two scripts and assign a shortcut key to each.(copy / pate) Python is not easy. Ask for help.
import c4d def main(): sel_pt = op.GetPointS() id_sel_pt = 0 for i in range(op.GetPointCount()): if sel_pt.IsSelected(i): id_sel_pt = i objectmg = op.GetMg() selgmg = op.GetPoint(id_sel_pt) * objectmg print(selgmg) c4d.CopyStringToClipboard(selgmg) if __name__ == '__main__': main()
Paste Clipboard --> c4d.GetStringFromClipboard() Move Point --> op.SetPoint(id,c4d.Vector())
@ymoon
selgmg is a c4d.Vector, while GetStringFromClipboard expects a string, so Python uses the str function to convert, which results in an unwieldy string like Vector(50, 0, 0) If you want to put that string back into a vector, you need to parse it - I don't think there is an API function that does that.
selgmg
c4d.Vector
str
Vector(50, 0, 0)
However, you can solve the parsing issue pretty quickly by putting a JSON string to the clipboard instead which represents the three components of the vector:
import c4d import json def main(): sel_pt = op.GetPointS() id_sel_pt = 0 for i in range(op.GetPointCount()): if sel_pt.IsSelected(i): id_sel_pt = i objectmg = op.GetMg() selgmg = op.GetPoint(id_sel_pt) * objectmg selgmgStr = json.dumps([selgmg.x, selgmg.y, selgmg.z]) print(selgmg, selgmgStr) c4d.CopyStringToClipboard(selgmgStr) if __name__ == '__main__': main()
Then the readback would be just as easy:
import c4d import json def main(): selgmgStr = c4d.GetStringFromClipboard() selgmgList = json.loads(selgmgStr) selgmg = c4d.Vector(selgmgList[0], selgmgList[1], selgmgList[2]) print(selgmg, selgmgList, selgmgStr) sel_pt = op.GetPointS() id_sel_pt = 0 for i in range(op.GetPointCount()): if sel_pt.IsSelected(i): id_sel_pt = i objectmg = op.GetMg() op.SetPoint(id_sel_pt, selgmg * ~objectmg) op.Message (c4d.MSG_UPDATE) c4d.EventAdd() if __name__ == '__main__': main()
Python for C4D scripting: https://www.patreon.com/cairyn
@cairyn It Works. Thank You. Very Much.
