I'm looking to create some node alignment scripts (Align Vertical, Align Horizontal), and to do that, I believe I'll need the following information:
Which (if any) of the above methods currently exist?
I'll edit this post if my own research turns up anything useful.
As i said in the other thread, the current active node editor can't be retrieve.
The selected nodes are information that is not stored inside the editor itself but inside the node system. So you can retrieve them using GetSelectedNodes. Be sure to use the one in the GraphModelHelper class and not the old one.
Grid spacing + positioning
I'm not sure you can define your own grid spacing.
All the other questions cannot be answer if you cannot retrieve the active node editor.
Cheers, Manuel
Not the answer I was hoping for, but helpful nonetheless! Thank you.
